Remote Starting a Stationary Engine
davedb
Posted: November 15, 2020 at 2:06 AM / IP Logged Link to Post Post Reply Quote davedb
Hello all I’m looking to remotely start a compressor engine used to blow out slurry pipes I have a remote control already the outputs are a momentary signal (one for start and one for stop) what I need is a circuit that will turn on the ignition, run a heater plug for 20-30 seconds and then engage starter until it fires
The engine has a oil pressure switch and Alternator charging light could these be used to turn off the starter when started? I’d also need some kind of timer so if the engine didn’t start it wouldn’t keep cranking any help would be much appreciated
Dave
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
