2013 Volkswagen Jetta GLI, Radio & Remote Starter Wiring Diagram
sfxgeek
Posted: November 18, 2020 at 10:59 PM / IP Logged Link to Post Post Reply Quote sfxgeek
Trying to replace the factory Delphi double din radio and install a remote starter and can’t find any wiring diagrams anywhere for this car. Can anybody point me in the right direction please ? Have been scouring the internet for weeks and keep coming up empty handed.
Btw this is for the push to start edition of the car .
Thanks in advance
J
Learning car installs for my kids cars
mgoetz74
Silver - Posts: 424
Posted: November 19, 2020 at 9:35 AM / IP Logged Link to Post Post Reply Quote mgoetz74
only two remote starts work on that car...
compustar
CMVWXA0-don't have to loose a key-uses factory key fob and push lock button 3x to remote start
RS1B-DC3-loose a key- a key will have to stay in the vehicle at all times
as far as the radio what are you trying to do? if replacing just use a data bus harness and make life simpler- pac RP4-VW11
sfxgeek
Posted: November 19, 2020 at 3:06 PM / IP Logged Link to Post Post Reply Quote sfxgeek
Thanks for your reply, the starter that I purchased (because I was told it would work on my car, maybe I got scammed) is a Firstech DC3-LC Start It. I have it installed with the T harness and when I go to program it all the right LEDs flash green like it's happy, but when I go to try to remote start it gives an error code of 8 light flashes which according to the online manual means the tach isn't programmed correct, and on the dashboard there is "remote out of range" message that comes up.
As for the deck I bought a Planet Audio P9950CPA and was just unclear on a couple of the wirings needed , that's why I was looking for the wiring diagrams for the car.
Any help is greatly appreciated.
J
mgoetz74
Silver - Posts: 424
Posted: November 20, 2020 at 9:52 AM / IP Logged Link to Post Post Reply Quote mgoetz74
firstech is the same company a compustar. Probably just need to program the tach which is usually start vechile, push and hold brake pedal, push programing button on side of remote start brain, let off brake. leds should turn green and parking lights should flash. I couldn't find a manual for that RS you mentioned but all compustars work the same way. as For the key error code I think that normal (not 100%) and should go away when your get in the car
or start car, push and hold brake pedal, push and hold RS (about 3 seconds) button on the remote let off brake pedal
Monday, November 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
