Does Viper 4704 Starter Have Alarm Abilities?
bassneedle
Posted: December 23, 2020 at 3:03 PM / IP Logged Link to Post Post Reply Quote bassneedle
Seems the door cant trigger alarm. Or I did something wrong with install or programing. Was controlling oem security before.
What module would add alarm?
bassneedle
Posted: December 23, 2020 at 3:05 PM / IP Logged Link to Post Post Reply Quote bassneedle
95 Toyota t100 truck. no special key.
was just testing on bench
panic will make siren go and arm diarm etc. door works for detecting open door, but no alarm trigger
Platinum - Posts: 7,828
Posted: December 23, 2020 at 3:31 PM / IP Logged Link to Post Post Reply Quote kreg357
The Viper 4704 is just a R/S with RKE, it has no alarm functions. It does have Door, Hood and Trunk pin inputs but they are for a Manual Transmission vehicle install to support Reservation Mode. You would need to go to a 570x system to get alarm functions. If the truck has a factory alarm system that beeps the horn you could set a jumper and connect the H2-19 Blue wire to the trucks horn. That would send an alert to the Vipers 2-Way remote if the horn was beeping for more than 0.5 seconds.
bassneedle
Posted: December 23, 2020 at 3:45 PM / IP Logged Link to Post Post Reply Quote bassneedle
yeah that's how I had it hooked up in a different vehicle. This truck doesn't have any horn honk alarm. What alarm module is good to run off the ground when armed?
