2019 Toyota Highlander, Non-JBL Speaker Wire Colors
coolie2609
Posted: April 21, 2021 at 3:18 PM / IP Logged Link to Post Post Reply Quote coolie2609
2019 toyota highlander
Non jlb xle v6
6 speakers (2 indash 4 indoors)
I want adding 2 amps myself along with lc7i audio control to put back bass into speakers.
I need speakers wire colors and or pin connector location including two dash tweeters .
From my research it seems speakers are routed through two connectors and not just 1.
I'm getting different answers and different colors. Please help.
Ez
mgoetz74
Silver - Posts: 424
Posted: April 22, 2021 at 9:59 AM / IP Logged Link to Post Post Reply Quote mgoetz74
Radio 12V     Lt. Blue or Lavender/Lt. Blue     +     Radio, white 10 pin plug, pin 4
Radio Ground     Brown     -     Radio, white 10 pin plug, pin 7
Radio Ignition     Gray     +     Radio, white 10 pin plug, pin 3
Radio Illumination     Green (parking lights); White (dimmer)     +,-     Radio, white 10 pin plug, pin 10 (parking lights); white 6 pin plug, pin 5 (dimmer)
Left Front Speaker (+/-)     Lavender/Black - Lavender/Gray or Brown - Lt. Blue     +,-     Radio, white 10 pin plug, pins 2 - 6
Right Front Speaker (+/-)     Lt. Green - Blue or White - Black or Lt. Green - Pink     +,-     Radio, white 10 pin plug, pins 1 - 5
Left Rear Speaker (+/-)     Blue - Red or Green - Red     +,-     Radio, white 6 pin plug, pins 2 - 6
Right Rear Speaker (+/-)     Pink - Gray     +,-     Radio, white 6 pin plug, pins 1 - 3
Left Front Speaker - With Amp     Pink - Violet     +,-     Amplifier under center console, white 30 pin plug, pins 11 - 26
Right Front Speaker - With Amp     Lt. Green - Blue     +,-     Amplifier under center console, white 30 pin plug, pins 15 - 30
Left Front Tweeter - With Amp     Black - Gray     +,-     Amplifier under center console, white 30 pin plug, pins 13 - 28
Right Front Tweeter - With Amp     White - Black or Lt. Green - Blue     +,-     Amplifier under center console, white 30 pin plug, pins 14 - 29
Left Rear Speaker - With Amp     Blue - Red     +,-     Amplifier under center console, white 30 pin plug, pins 4 - 19
Right Rear Speaker - With Amp     Pink - Gray     +,-     Amplifier under center console, white 30 pin plug, pins 12 - 27
Left Rear Surround - With Amp     Yellow - Tan     +,-     Amplifier under center console, white 30 pin plug, pins 5 - 20
Right Rear Surround - With Amp     Red - White     +,-     Amplifier under center console, white 30 pin plug, pins 9 - 24
Center Channel - With Amp     Lt. Blue - Brown     +,-     Amplifier under center console, white 30 pin plug, pins 10 - 25
Subwoofer - With Amp     Black - Lt. Blue (coil 1); Yellow - Gray (coil 2)     +,-     Amplifier under center console, white 30 pin plug, pins 8 - 23 (coil 1); pins 7 - 22 (coil 2)
Aux. Audio Input Left (+/-)     White - Black     +,-     Radio, white 28 pin plug, pins 28 - 27
Aux. Audio Input Right (+/-)     Red - Black     +,-     Radio, white 28 pin plug, pins 26 - 27
Rearview Camera Video     Red - White or Green - Red     +,-     Radio, white 24 pin plug, pins 12 - 24
RSE Audio Left (+/-)     Black - Green     +,-     Radio, white 12 pin plug, pins 4 - 5
RSE Audio Right (+/-)     Red - White     +,-     Radio, white 12 pin plug, pins 2 - 3
Satellite Radio 12 Volts     Red     +     Satellite Radio below radio, white 8 pin plug, pin 4
Satellite Radio Ground     Black     -     Satellite Radio below radio, white 8 pin plug, pin 8
Satellite Radio Ignition     Yellow     +     Satellite Radio below radio, white 8 pin plug, pin 3
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     (DIN cable)
Satellite Audio Right (+/-)     (DIN cable)
coolie2609
Posted: April 28, 2021 at 12:28 PM / IP Logged Link to Post Post Reply Quote coolie2609
2019 Toyota Highlander, Non-JBL Speaker Wire Colors - Last Post -- posted image.
right on the money. hard to find info no this vehicle so thank you so much.
Ez
Monday, June 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
