2006 Nissan Almera, Alarm Wiring
jubz91
Posted: April 26, 2021 at 8:01 PM / IP Logged Link to Post Post Reply Quote jubz91
Hi All,
Sorry if this is not the right place to request this is the first time im requesting.
Does anyone know or have the diagram for a Nissan Almera 2006 wiring for an alarm kit available?
Thank you in advance
Juber Rahman
Platinum - Posts: 13,726
Posted: April 29, 2021 at 11:02 PM / IP Logged Link to Post Post Reply Quote i am an idiot
That looks like the Sentra that is sold over here. This is the info for the Sentra. You need to verify the following info to make sure it is the same as yours.
12 Volts      white/red (40A)      +      ignition switch, white 6 pin plug, pin 3      Directwire
Ground      (chassis ground)
Starter      black/white      +      ignition switch, white 6 pin plug, pin 2      Directwire
Second Starter      black/yellow      +      ignition switch, white 6 pin plug, pin 6      Directwire
Ignition      black/red      +      ignition switch, white 6 pin plug, pin 1      Directwire
Accessory      white      +      ignition switch, white 6 pin plug, pin 4      Directwire
Second Accessory      white/blue      +      ignition switch, white 6 pin plug, pin 5      Directwire
Ignition Interrupt      green/white      cut      Immobilizer Control Unit on ignition switch, white 8 pin plug, pin 2
Keysense      blue/white (with power lock)      +      SECU right of steering column, black 24 pin plug, pin 14      Directwire      Notes
IMMO Data      brown/yellow      data      Immobilizer Control Unit on ignition switch, white 8 pin plug, pin 8
Security Light      gray/red      -      Immobilizer Control Unit on ignition switch, white 8 pin plug, pin 4
Power Lock      gray      -      SECU right of steering column, black 24 pin plug, pin 5      Directwire
Power Unlock      violet/red      -      SECU right of steering column, black 24 pin plug, pin 17      Directwire
Lock Motor      red/black      5 wire      SECU right of steering column, white 18 pin plug, pin 15      Directwire
Driver Unlock Motor      blue/red      5 wire      SECU right of steering column, white 18 pin plug, pin 13      Directwire
Passenger Unlock Motor      white/red      5 wire      SECU right of steering column, white 18 pin plug, pin 14      Directwire
Factory Alarm Arm      lt. green/red (driver door key lock)      -      SECU right of steering column, black 24 pin plug, pin 23
Factory Alarm Disarm      white/blue (driver door key unlock)      double -      SECU right of steering column, black 24 pin plug, pin 12
Disarm No Unlock      see factory alarm disarm
Trunk Alarm Shunt      blue/orange (trunk key cylinder)      -      SECU right of steering column, black 24 pin plug, pin 24
Parking Lights      white/red or red/blue      +      headlight switch or driver kick, harness to rear      Directwire
Hazards      orange/black (with keyless only)      -      SECU right of steering column, white 18 pin plug, pin 7      Directwire
Turn Signal (Left)      green/black      +      driver kick, harness to rear
Turn Signal (Right)      green/yellow      +      driver kick, harness to rear
Headlight      red/yellow (L); violet (R)      +      headlight switch, brown 4 pin plg, pin 3; brown 8 pin plg, pin 3      Directwire
Reverse Light      green/yellow      +      driver kick, harness to rear      Directwire
Left Front Door Trigger      red/white (w/o power lock); red (with power lock)      -      driver kick; SECU right of steering column, black 24 pin plug, pin 11      Directwire
Right Front Door Trigger      same as LF (w/o pwr lock); red/white (w/pwr lock)      -      SECU right of steering column, black 24 pin plug, pin 10      Directwire
Left Rear Door Trigger      same as right front door trigger
Right Rear Door Trigger      same as right front door trigger
Dome Light      same as LF (w/o pwr lock); red/yellow (w/pwr lock)      -      SECU right of steering column, white 18 pin plug, pin 8      Directwire
Trunk/Hatch Pin      red/black      -      trunk pin switch or SECU right of steering column, black 24 pin plug, pin 20      Directwire
Trunk/Hatch Release      red      -      trunk release switch or relay to right of fuse box      Directwire
Trunk Release Motor      pink/black      -high curr      driver kick or SECU right of steering column, white 18 pin plug, pin 12      Directwire
Tachometer      NOT black/red (1.8L) or pink (2.5L)      ac      any fuel injector      Directwire      Notes
Neutral Safety      green/orange (M/T)      -      ECM on passenger firewall, black 40 pin plug, pin 21
Clutch Pedal      black/red      -      clutch switch, blue 2 pin plug, pin 1
Fuel Pump      black/yellow      +      driver kick, harness to rear      Directwire
Rear Defroster      green/black (with power lock)      -      SECU right of steering column, black 24 pin plug, pin 21      Directwire      Notes
Mirror Defroster      same as rear defroster
Speed Sense      red/yellow (without tachometer)      ac      instrument cluster, brown 20 pin plug, pin 5           Notes
Brake Wire      red/green      +      brake switch or driver kick, harness to rear      Directwire
Parking Brake      yellow/black      -      driver kick, harness to rear      Directwire
Horn Trigger      white/green      -      horn switch or SECU right of steering column, black 24 pin plug, pin 1      Directwire
Wipers      green/red (L), green/white (H), black (ground)      -      wiper switch, gray 8 pin plug, pins 5, 4, and 6      Directwire
Left Front Window (Up/Down)      green/red - blue      A      power window main switch, white 16 pin plug, pins 2 and 1
Right Front Window (Up/Down)      red/white - red      A      driver kick, white 8 pin plug, pins 1 and 4
Left Rear Window (Up/Down)      yellow - yellow/black      A      driver kick, white 4 pin plug, pins 3 and 4
Right Rear Window (Up/Down)      green/white - green      A      driver kick, white 4 pin plug, pins 1 and 2
Sun Roof (Open/Close)      blue/black - blue/red (function with ign on only)      +      sunroof switch, white 4 pin plug, pins 1 and 4
jubz91
Posted: April 30, 2021 at 2:58 AM / IP Logged Link to Post Post Reply Quote jubz91
Thank you very much,
Yesm you are correct, I believe it is also called the Sentra.
When I do it I will look into the wiring and will update if everything is correct or do corrections IF i can and manage to find the wires.
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
