2015 Ram 1500, Master Switch Door Lock Issue
Platinum - Posts: 13,726
Posted: June 11, 2021 at 4:27 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Disconnect the battery(ies). Ground a meter lead to the chassis of vehicle. Set meter to ohms or 2000 ohms. Stick the other lead into the wire socket that plugs into the switch. Hit lock and unlock on the switch to see which wire changes reading when you lock and unlock. The wire may be a different color in the drivers door.
alfwc55
Member - Posts: 7
Posted: June 11, 2021 at 5:02 PM / IP Logged Link to Post Post Reply Quote alfwc55
Turns out to be both, a faulty switch and control module. All is working again. Thanks for the help.
alfwc55
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
