eagle talon keyless entry
black_dsm
Posted: June 24, 2002 at 2:34 PM / IP Logged
hi everyone,
well, this is my first post here, so bare w/ me.  this is also my first alarm install so i still have alot to learn. my problem is that i'm trying to install keyless entry on my 90 eagle talon tsi and i can't seem to get it to work.   my alarm is the alpine 8028 and has built in relays for the door locks, but i can't seem to get them to work.  there are three wires going to the actuator if that means anything.  i assume that it means it's a 3 wire setup, but i'm not sure.
has anyone here done this on a talon before or know how to do it?  any help would be much appreciated.  thanks,
james
Chris Luongo
Platinum - Posts: 3,746
Posted: June 24, 2002 at 10:25 PM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|        ACCESSORY|blue/black          |+  |ignition harness            |
|       POWER LOCK|BROWN / blue          |-  |relays right of column      |
|     POWER UNLOCK|BROWN / white         |-  |relays right of column      |
| PARKING LIGHTS +|GREEN / WHITE         |   |above hood release          |
| PARKING LIGHTS -|blue/white or gray  |   |steering column             |
|       HEADLIGHTS|red                 |-  |steering column             |
|     DOOR TRIGGER|GREEN/ red           |-  |above hood release          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|common with doors   |   |                            |
|FCTRY ALRM DISARM|brn/wht or brn/blk  |-  |DKP harness from door       |
|       TACHOMETER|white               |   |instrument cluster *1       |
|       BRAKE WIRE|green               |+  |brake pedal switch          |
|     HORN TRIGGER|grn/blk and grn/wht |-/+|steering column *2          |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|red - green         |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blu - blk/blu   |A  |in drivers door or dkp      |
Notes:
*1 Also found at a connector above the hood release.  *2 Steering column wire is neg. on GREEN/ black. The other side of the horn rests at ignition on GREEN / WHITE. Find GREEN / WHITE at fuse box, fuse number 10, 10 amp. Use two relays, one to throw pos. to GREEN / WHITE and one to throw neg. to GREEN/ black at steering column.
Platinum - Posts: 12,488
Posted: June 24, 2002 at 10:35 PM / IP Logged
  • POWER LOCK: BROWN / blue         goes to the WHITE/ BROWN on Alpine
  • POWER UNLOCK: BROWN / white       goes to the WHITE/ BROWN on Alpine
  • GREEN/ RED & BROWN / RED wire goes to GROUND
black_dsm
Posted: June 26, 2002 at 12:52 AM / IP Logged
cool.........thanks alot for the help.
