2004 Dodge Ram 3500 Diesel, Compustar DC3, Door Lock Wiring
scottthur
Posted: June 29, 2021 at 4:09 PM / IP Logged Link to Post Post Reply Quote scottthur
Im looking to install a Compustar DC3 in my 2004 Ram 3500. I looked over the idatalink install guide and it shows 2 relays used and one 330 ohm resistor. The resistor appears to be for the parking lights. Looking through the posts here I have read more relays and resistors will be needed for the locks. Is there a wiring diagram for the DC3 that shows relay connections for the locks?
Platinum - Posts: 13,726
Posted: June 30, 2021 at 7:59 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Power Lock      Violet/Dk. Green      - 820 Ohms      Above Driver Kick, white 24 pin plug, pin 18      Directwire
Power Unlock      (same as power lock)      - 330 Ohms
Above is the wiring info for the truck. It will take 2 relays.
mgoetz74
Silver - Posts: 424
Posted: July 02, 2021 at 12:46 PM / IP Logged Link to Post Post Reply Quote mgoetz74
the dc3 has a door lock mux wire that should do the lock/unlock. yellow wire m4 and hooked to purple/ltblue in the drivers kick panel. shouldn't need a relay
