2015 Chevrolet City Express, Remote Start Wiring?
bretttt
Posted: July 30, 2021 at 3:01 PM / IP Logged Link to Post Post Reply Quote bretttt
Just purchased a 2015 Chevy city express. I want to install keyless entry and remote start. Can’t find any info anywhere.
Also I know the city express is basically the Nissan nv200 with chevy badges. Would anyone know if that info would be the same?
wirewise
Moderator - Posts: 489
Posted: July 30, 2021 at 5:22 PM / IP Logged Link to Post Post Reply Quote wirewise
CHEVROLET CITY EXPRESS
CITY EXPRESS     2015
KEY     T-HARNESS     IMMOBILIZER
N/A     N/A     Transponder type anti-theft
PART     COLOR     LOCATION     DIAGRAM
12 VOLT CONSTANT     BLUE (+)     ignition switch, white 6 pin plug, pin 3
STARTER     WHITE (+)     ignition switch, white 6 pin plug, pin 2
STARTER 2     N/A
IGNITION 1     RED (+)     ignition switch, white 6 pin plug, pin 1
IGNITION 2     N/A
IGNITION 3     N/A
ACCESSORY/HEATER BLOWER 1     YELLOW (+)     ignition switch, white 6 pin plug, pin 4
ACCESSORY/HEATER BLOWER 2     BROWN (+)     ignition switch, white 6 pin plug, pin 5
KEYSENSE     WHITE (+)     key switch or BCM behind glove box, white 40 pin plg, pin 37 or 24
PARKING LIGHTS ( - )     N/A
PARKING LIGHTS ( + )     PURPLE (+)     driver firewall, harness from engine compartment
POWER LOCK     PINK (-) DRIVER DOOR KEY LOCK, test by turning key in door to lock     driver kick or BCM behind glove box, white 40 pin plug, pin 8 or 13
POWER UNLOCK     BLACK (-) double unlock pulse DRIVERS DOOR KEY UNLOCK test wire by turning key to unlock     driver kick or BCM behind glove box, white 40 pin plug, pin 7 or 14
LOCK MOTOR WIRE     BLUE (5 WIRE)     driver kick or BCM behind glove box, white 15 pin plug, pin 14
DOOR TRIGGER     BROWN (-)     BCM behind glove box, black 15 pin plug, pin 4
DOMELIGHT SUPERVISION     BROWN (-)     BCM behind glove box, white 15 pin plug, pin 5
TRUNK RELEASE     N/A
SLIDING POWER DOOR     N/A
HORN     RED (-)     horn switch, gray 8 pin plug, pin 5
TACH     BLUE,RED,YELLOW, or PURPLE (AC)     any fuel injector, gray 2 pin plug, pin 2
WAIT TO START LIGHT     N/A
BRAKE     RED (+)     brake switch or BCM behind glove box, white 40 pin plug, pin 9 or 12
FACTORY ALARM DISARM     BLACK (-)     driver kick or BCM behind glove box, white 40 pin plug, pin 7 or 14
ANTI-THEFT     TRANSPONDER TYPE requires extra key in bypass module     To remote start without leaving a key in the bypass, use a DBALL2 interface.
~wirewise~
Tuesday, May 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
