2012 Chevrolet Spark Lite LS, 5 Door, Wiring
matthew le roux
Posted: September 29, 2021 at 1:38 AM / IP Logged Link to Post Post Reply Quote matthew le roux
Good day
Does anyone have the wire speck sheet for a Chevrolet Spark lite 2012 LS 5dr please.
Mat
Platinum - Posts: 13,716
Posted: September 29, 2021 at 6:42 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio, Alarm, whole car?
matthew le roux
Posted: September 29, 2021 at 11:00 PM / IP Logged Link to Post Post Reply Quote matthew le roux
Hi, Yes, that would be awesome.
Mat
mgoetz74
Silver - Posts: 424
Posted: September 30, 2021 at 4:04 PM / IP Logged Link to Post Post Reply Quote mgoetz74
we didn't get the spark in the US till 2013 and haven't heard of a spark lite so I don't know it it the same but this in the 2013 info I have-
12 Volts     Red/Green (30A)     +     BCM above driver kick, blue 27 pin plug, pin 4
Second 12 Volts     Red/Green (2A only)     +     Ignition Switch, gray 6 pin plug, pin 5
Ground     (chassis ground)
Starter     Yellow (for starter kill only)     +     Starter Motor or Underhood Fuse Box, gray 32 pin plug (X3), pin 28
Second Starter     White/Violet (R Code) (see Tech Doc 1605)     + 9600 Ohms     Ignition Switch, gray 6 pin plug, pin 3
Ignition     Violet/Black     +     Ignition Switch, gray 6 pin plug, pin 4
Accessory     Violet/Yellow     +     Ignition Switch, gray 6 pin plug, pin 6
Second Accessory     (same as second starter)     + 6300 Ohms
Keysense     (same as second starter)
CAN Bus High     Blue     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     White     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus SW     Green     Data     OBD-Data Link Connector, black 16 pin plug, pin 1
OBD 12 Volts     Red/Brown (10A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
IMMO Data     Green/Violet     Data     Immobilizer Control Module on ignition switch, violet 3 pin plug, pin 2
Power Lock     brown/yellow     -     BCM above driver kick, pink 27 pin plug, pin 15
Power Unlock     brown/white     -     BCM above driver kick, gray 26 pin plug, pin 14
Lock Motor     brown/yellow     5 wire     BCM above driver kick, pink 27 pin plug, pin 4
Driver Unlock Motor     gray     5 wire     BCM above driver kick, pink 27 pin plug, pin 1
Passenger Unlock Motor     gray     5 wire     BCM above driver kick, pink 27 pin plug, pin 2
Factory Alarm Arm     yellow/brown (driver door key lock)     -     BCM above driver kick, gray 26 pin plug, pin 19
Factory Alarm Disarm     blue/violet (driver door key unlock)     -     BCM above driver kick, gray 26 pin plug, pin 13
Disarm No Unlock     (transponder and ignition)
Parking Lights     violet/gray (L); gray/brown (R)     +     BCM above driver kick, black 26 pin plug, pins 6, 5
Parking Lights -     Green/Gray     -     Headlight Switch, black 9 pin plug, pin 2
Hazards     green/white     -     BCM above driver kick, blue 27 pin plug, pin 26
Turn Signal (Left)     blue/white (F); blue/white (R)     +     BCM above driver kick, brown 26 pin plug, pins 2, 1
Turn Signal (Right)     green/violet (F); blue/violet (R)     +     BCM above driver kick, black 26 pin plug, pins 3, 4
Headlight     white/violet     -     headlight switch, black 9 pin plug, pin 3
Reverse Light     green/white     +     BCM above driver kick, gray 26 pin plug, pin 3
Left Front Door Trigger     Gray     -     BCM above driver kick, pink 27 pin plug, pin 22
Right Front Door Trigger     gray     -     BCM above driver kick, pink 27 pin plug, pin 13
Left Rear Door Trigger     gray     -     BCM above driver kick, pink 27 pin plug, pin 27
Right Rear Door Trigger     gray     -     BCM above driver kick, gray 26 pin plug, pin 11
Dome Light     gray     +     BCM above driver kick, gray 26 pin plug, pin 1
Trunk/Hatch Pin     violet/gray     -     BCM above driver kick, pink 27 pin plug, pin 5
Hood Pin     brown/green     -     BCM above driver kick, black 26 pin plug, pin 24
Trunk/Hatch Release     blue (lock); green (unlock) (without power door locks)     -     BCM above driver kick, pink 27 pin plug, pin 15; gray 26 pin plug, pin 14
Trunk Release Motor     (same as lock motor and passenger unlock motor)
Tachometer     green/yellow, brown/yellow, yellow/white, or brown/violet     ac     above fuel rail, black 8 pin plug, pin E, F, G, or H
Clutch Pedal     Yellow     Resistor     Clutch Switch, black 3 pin plug, pin B          Notes
Fuel Pump     gray     +     underhood fuse box, black 44 pin plug (X2), pin 36
Rear Defroster     blue/white     -     BCM above driver kick, blue 27 pin plug, pin 14
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     brown/gray     + latched     driver seat heating switch, 6 pin plug, pin 3
Right Front Heated Seat     yellow/blue     + latched     passenger seat heating switch, 6 pin plug, pin 3
Speed Sense     yellow (A/T); brown/white (M/T)     ac     TCM, white 26 pin plug, pin 14; ECM, black 56 pin plug, pin 27
Brake Wire     violet/white or white/yellow     +     BCM above driver kick, black 26 pin plug, pin 11
Parking Brake     blue/violet     -     BCM above driver kick, gray 26 pin plug, pin 15
Horn Trigger     brown/white     -     BCM above driver kick, brown 26 pin plug, pin 19
Wipers     gray     +     BCM above driver kick, black 26 pin plug, pin 16
Left Front Window (Up/Down)     green/gray - yellow/violet     A     driver window switch, white 6 pin plug, pins 5 - 2 or white 14 pin plug, pins 9 - 7
Right Front Window (Up/Down)     yellow/black - brown/yellow     A     driver kick, door harness
Left Rear Window (Up/Down)     green/gray - brown/blue     A     driver kick, door harness
Right Rear Window (Up/Down)     green/gray - brown/blue     A     driver kick, door harness
Radio 12V     red/blue     +     radio, black 44 pin plug, pin 44
Radio Ground     black     -     radio, black 44 pin plug, pin 38
Radio Ignition     (low speed GMLAN)
Radio Illumination     (low speed GMLAN)
Left Front Speaker (+/-)     blue - brown/blue     +,-     radio, black 44 pin plug, pins 40 - 32
Right Front Speaker (+/-)     yellow - yellow/black     +,-     radio, black 44 pin plug, pins 39 - 31
Left Rear Speaker (+/-)     green - green/black     +,-     radio, black 44 pin plug, pins 42 - 34
Right Rear Speaker (+/-)     white - blue/black     +,-     radio, black 44 pin plug, pins 41 - 33
Aux. Audio Input Left (+/-)     gray - brown     +,-     radio, black 44 pin plug, pins 24 - 23
Aux. Audio Input Right (+/-)     green - brown     +,-     radio, black 44 pin plug, pins 10 - 23
RSE Video (+/-)     blue - black/white (aux. video)     +,-     radio, black 44 pin plug, pins 21 - 22
Satellite Radio 12 Volts     (built into radio)
matthew le roux
Posted: October 01, 2021 at 12:58 AM / IP Logged Link to Post Post Reply Quote matthew le roux
Thank you for this, i will have a lok and see if the wire colors are the same.
Mat
matthew le roux
Posted: October 04, 2021 at 2:53 AM / IP Logged Link to Post Post Reply Quote matthew le roux
Hi I had a look, and the wires don't match up. For the same car do you have the 2012 m250 daewoo matiz?
Mat
mgoetz74
Silver - Posts: 424
Posted: October 04, 2021 at 9:55 AM / IP Logged Link to Post Post Reply Quote mgoetz74
nothing daewoo
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
