installing xplode in tercel
efrain
Posted: June 10, 2003 at 10:26 AM / IP Logged
Hello I would like to know if I can obtain a diagram on installing the Sony Xplode Cdx-Ca810x into my 1991 Toyota Tercel if possible.
Sweekster
Silver - Posts: 481
Posted: June 10, 2003 at 10:51 AM / IP Logged
You might want to try this diagram.  It should help you out.
Does your car not have the factory wiring harness in it anymore?  If it does, then you probably want to get a harness adapter for it.  Maybe try Metra, Scosche, Best Kits or Crutchfield to find the harness and install kit to get the head unit in your car with little problem.  Good luck
efrain
Posted: June 10, 2003 at 12:09 PM / IP Logged
thanks sweekster i'm set!
Sweekster
Silver - Posts: 481
Posted: June 10, 2003 at 2:28 PM / IP Logged
no problem.
