1994 Chevrolet Suburban, Remote Start, Keyless Entry
thespark88
Posted: November 03, 2021 at 8:16 AM / IP Logged Link to Post Post Reply Quote thespark88
Hi guys
I have a compustar 920s that comes the cm-900 module
I have the basic wiring figured out. I just need help with the unlock/lock/ Parking lights/horn. I’ve spent 2 weeks trying to wrap my head around it and I think I’m just over complicating it.
1994 suburban
6.5 turbo diesel
Platinum - Posts: 7,828
Posted: November 03, 2021 at 10:03 AM / IP Logged Link to Post Post Reply Quote kreg357
Power Lock.........lt. blue (+).........@ either door boot \ Need relays to make (-) to (+) conversion
Power Unlock.......black/red (+)........@ either door boot / Use Door Lock Relay diagram in Relays section
The CM900 outputs (-) Door Lock/Unlock signals, your vehicle needs (+) signals.
    https://www.the12volt.com/relays/relaydiagram8.html
Parking Lights.....brown (+)............@ headlight switch...................CN1-2 Green/White
Horn Trigger.......black (-)............@ steering column harness............CN3-7 White
Main ignition harness
The two Red wires are +12V constant.
The Starter wire is Yellow or Violet.
The Ignition wire is Pink.
The two Accessories are Orange and Brown. Use the CM900 Blue at CN1-5 for the Brown ACC wire and set CM900 internal jumper to ACC.
thespark88
Posted: November 03, 2021 at 12:02 PM / IP Logged Link to Post Post Reply Quote thespark88
What about cn3-1 green with white?
1994 suburban
6.5 turbo diesel
Posted: November 03, 2021 at 12:21 PM / IP Logged Link to Post Post Reply Quote kreg357
That wire outputs a low power (-) Parking Light signal. Your vehicle needs a (+) signal to turn on the Parking Lights. The thick Green/White at CN1-2 is a (+) output rated at 10 amps.
