2018 Honda Fit, Standard Key, Remote Start Wiring
caraudioholic24
Member - Posts: 37
Posted: November 11, 2021 at 6:42 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Good Evening. I've looked everywhere but can't find any wiring info for 2018 Honda Fit Standard Key. Looking to do remote start. I miss my directech login..
Any help is greatly appreciated.
mgoetz74
Silver - Posts: 424
Posted: November 12, 2021 at 1:59 PM / IP Logged Link to Post Post Reply Quote mgoetz74
12 Volts     White (50A)     +     Ignition Switch, white 5 pin plug, pin 1
Ground     (chassis ground)
Starter     Green     +     Ignition Switch, white 5 pin plug, pin 5
Ignition     Red     +     Ignition Switch, white 5 pin plug, pin 2
Accessory     Lt. Green     +     Ignition Switch, white 5 pin plug, pin 4
Second Accessory     Yellow     +     Ignition Switch, white 5 pin plug, pin 3
Keysense     Pink     -     Key Switch, 7 pin plug, pin 7
CAN Bus High     White (F-CAN)     Data     OBD-Data Link Connector, 16 pin plug, pin 6
CAN Bus Low     Red (F-CAN)     Data     OBD-Data Link Connector, 16 pin plug, pin 14
CAN Bus High 2     Pink (B-CAN)     Data     Immobilizer Control Unit on ignition switch, gray 7 pin plug, pin 4
CAN Bus Low 2     Blue (B-CAN)     Data     Immobilizer Control Unit on ignition switch, gray 7 pin plug, pin 5
OBD 12 Volts     Red (10A)     +     OBD-Data Link Connector, 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, 16 pin plug, pin 4
IMMO Data     Blue (S-NET)     Data     Immobilizer Control Unit on ignition switch, gray 7 pin plug, pin 2
Power Lock     Green     -     Driver Kick, door harness --or-- Dash Fuse Box, rear, 24 pin plug (D), pin 17
Power Unlock     Gray     -     Driver Kick, door harness --or-- Dash Fuse Box, rear, 24 pin plug (D), pin 12
Lock Motor     Pink     Reverse     Dash Fuse Box, 52 pin plug (N), pin 16
Driver Unlock Motor     Gray     Reverse     Dash Fuse Box, 52 pin plug (N), pin 17
Factory Alarm Arm     White (driver door key lock)     -     Driver Kick, door harness --or-- Dash Fuse Box, rear, 24 pin plug (D), pin 11
Factory Alarm Disarm     Red (driver door key unlock)     -     Driver Kick, door harness --or-- Dash Fuse Box, rear, 24 pin plug (D), pin 10
Parking Lights     Gray     +     Dash Fuse Box, 18 pin plug (T), pin 1
Parking Lights -     Gray     -     Headlight Switch, white 12 pin plug, pin 8
Hazards     Pink     +     Dash Fuse Box, rear, 16 pin plug (A), pin 14
Turn Signal (Left)     Yellow     +     Dash Fuse Box, 52 pin plug (N), pin 4
Turn Signal (Right)     Green     +     Dash Fuse Box, 52 pin plug (N), pin 5
Headlight     White     -     Headlight Switch, white 12 pin plug, pin 7
AutoLights     Brown     - (Off)     Headlight Switch, white 12 pin plug, pin 1
Reverse Light     Brown     +     Dash Fuse Box, 52 pin plug (N), pin 1
Left Front Door Trigger     Brown     -     Dash Fuse Box, 52 pin plug (N), pin 18
Right Front Door Trigger     Green     -     Dash Fuse Box, 52 pin plug (N), pin 29
Left Rear Door Trigger     Gray     -     Dash Fuse Box, 52 pin plug (N), pin 34
Right Rear Door Trigger     White     -     Dash Fuse Box, 52 pin plug (N), pin 32
Dome Light     Violet     -     Dash Fuse Box, rear, 24 pin plug (D), pin 24
Trunk/Hatch Pin     Pink     -     Dash Fuse Box, 52 pin plug (N), pin 21
Hood Pin     Tan     - N.C.     Dash Fuse Box, 40 pin plug (Q), pin 30
Trunk/Hatch Release     (locks/unlocks along with doors)
Tachometer     Green     ac     Camshaft Position Sensor, engine driver side, 3 pin plug, pin 3
Clutch Pedal     Lt. Green     -     Clutch Switch, 4 pin plug, pin 4
Fuel Pump     Green     +     Dash Fuse Box, rear, 8 pin plug (F), pin 3
Rear Defroster     Lt. Blue     - Latched     Dash Fuse Box, rear, 16 pin plug (A), pin 16 (w/o climate control); Climate Control Unit, 32 pin plug, pin 6 (w/climate cntrl)
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     Green (LO); White (HI)     + Latched     Driver Seat Heater Switch, 7 pin plug, pins 4, 1
Right Front Heated Seat     Red (LO); Blue (HI)     + Latched     Passenger Seat Heater Switch, 6 pin plug, pins 4, 1
Speed Sense     Blue (some models only)     ac     Radio, 24 pin plug (C), pin 14 --or-- Below Dash Fuse Box, 25 pin plug, pin 18
Brake Wire     Lt. Green     +     Brake Switch --or-- Dash Fuse Box, 40 pin plug (Q), pin 8
Parking Brake     Blue     -     Parking Brake Switch, 1 pin plug, pin 1
Horn Trigger     Violet     -     Horn Switch-Clock Spring, 20 pin plug, pin 2
Wipers     Blue     -     Dash Fuse Box, 40 pin plug (Q), pin 24
caraudioholic24
Member - Posts: 37
Posted: November 12, 2021 at 4:55 PM / IP Logged Link to Post Post Reply Quote caraudioholic24
Thank you soo much.. You all are awesome
Sunday, November 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
