2005 Buick Century, Remote Start Wiring
fgmario
Posted: November 11, 2021 at 7:05 PM / IP Logged Link to Post Post Reply Quote fgmario
anybody got wiring to install remote start in buick century 2005 thank.
fgcruiser
mgoetz74
Silver - Posts: 424
Posted: November 12, 2021 at 2:00 PM / IP Logged Link to Post Post Reply Quote mgoetz74
12 Volts     red (60A)     +     ignition harness
Second 12 Volts     red (30A)     +     ignition harness
Ground     (chassis ground)
Starter     yellow     +     ignition harness
Ignition     pink     +     ignition harness
Second Ignition     white to dk. green     +     ignition harness
Accessory     orange     +     ignition harness
Second Accessory     brown     +     ignition harness
R Code     white to white/black     VATS     ignition key cylinder
Reference Ground     white to violet/white     VATS     ignition key cylinder
Keysense     lt. green     -     ignition harness or BCM left of steering column, purple plug, pin A1
J1850     violet     data     OBD-data link connector, black 16 pin plug, pin 2
Power Lock     red/black     -     BCM left of steering column, purple plug, pin B6
Power Unlock     orange/black     -     BCM left of steering column, purple plug, pin A6
Lock Motor     gray     5 wire     BCM left of steering column, white plug, pin G
Driver Unlock Motor     tan     5 wire     BCM left of steering column, white plug, pin E
Parking Lights     lt. blue (larger of 2)     +     headlight switch
Parking Lights -     gray/black     -     BCM left of steering column, lt. blue plug, pin A4
Hazards     same as turn signals
Turn Signal (Left)     lt. blue (F), yellow (R)     +     steering column
Turn Signal (Right)     dk. blue (F), dk. green (R)     +     steering column
Headlight     yellow     -     BCM left of steering column, lt. blue plug, pin B5
Reverse Light     dk. blue     -     BCM left of steering column, lt. blue plug, pin A8
Left Front Door Trigger     dk. blue/white (all doors), dk. blue (driver door)     -     BCM left of steering column, purple plug, pins A5 and B5
Right Front Door Trigger     see left front door trigger
Left Rear Door Trigger     see left front door trigger
Right Rear Door Trigger     see left front door trigger
Dome Light     white     -     BCM left of steering column, blue plug, pin A
Trunk/Hatch Pin     orange/black     -     BCM left of steering column, lt. blue plug, pin B4
Trunk/Hatch Release     white     -     BCM left of steering column, purple plug, pin A7
Trunk Release Motor     black/white     +     passenger kick, harness to rear
Tachometer     violet/white or white     ac     Ignition Control Module on top rear of the engine
Fuel Pump     gray     +     underhood fuse box, fuel pump relay
Rear Defroster     white     - latched     defogger switch
Left Front Heated Seat     lt. blue (on) and pink (lo/hi)     +, +resist     driver heated seat switch
Right Front Heated Seat     lt. blue/black (on) and pink/black (lo/hi)     +, +resist     passenger heated seat switch
Speed Sense     dk. green/white     4K     PCM in air cleaner assembly, blue plug, pin 55          Notes
Brake Wire     white     +     brake pedal switch or steering column
Parking Brake     lt. blue     -     BCM left of steering column, purple plug, pin A2
Horn Trigger     black     -     steering column or BCM left of steering column, lt. blue plug, pin A5
Wipers     gray (low and high), yellow (ignition)     +     steering column
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
