2021-22 Ford E-350, Alarm Wiring
omaga
Posted: April 02, 2022 at 5:43 PM / IP Logged Link to Post Post Reply Quote omaga
Good evening all and thank you in advance not sure if posting in the right section ! I’m looking for an alarm wiring diagram for a 21 through 22 Ford E350 cutaway .
Thank you all
Platinum - Posts: 13,726
Posted: April 02, 2022 at 7:24 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      Red (50A)      +      BCM-Dash Fuse Box, black 22 pin plug (J7-G), pin 22
Second 12 Volts      Green/Red (7.5A)      +      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 24
Ground      (chassis ground)
Ground 2      Black/Blue      -      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 14
Starter Kill      Brown/Green      +      Underhood Fuse Box, black 50 pin plug, pin 4
Starter      Blue/White      +      Ignition Switch, black 7 pin plug, pin 7
Ignition      White/Orange      +      Ignition Switch, black 7 pin plug, pin 1
Accessory      Violet/Green or Violet/Orange      +      Ignition Switch, black 7 pin plug, pin 6
Keysense      Blue/Gray      +      Ignition Switch, black 7 pin plug, pin 5
CAN Bus High      Blue (HS1 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 20
CAN Bus Low      White (HS1 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 19
CAN Bus High 2      Gray/Orange (MS CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 23
CAN Bus Low 2      Violet/Orange (MS CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 22
CAN Bus High 3      Green/Orange (HS2 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 18
CAN Bus Low 3      Gray/Blue (HS2 CAN)      Data      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 17
OBD 12 Volts      White/Red (10A)      +      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 13
OBD Ground      Black/Blue      -      Gateway Module on OBD-Data Link Connector, black 24 pin plug, pin 1
OBD Connector      Black           Under Driver Dash, Above Parking Brake
IMMO Data      Blue (LIN)      Data      PATS Transceiver on ignition Switch, black 4 pin plug, pin 3
Power Lock      Gray      -      Driver Kick, door harness, gray 12 pin plug, pin 3
Power Unlock      Violet      -      Driver Kick, door harness, gray 12 pin plug, pin 4
Power Lock2      Gray (alternate location)      -      BCM-Dash Fuse Box, blue 52 pin plug (J5-E), pin 17
Power Unlock2      Violet (alternate location)      -      BCM-Dash Fuse Box, blue 52 pin plug (J5-E), pin 4
Lock Motor      Gray/Brown      Reverse      Driver Kick, door harness, 8 pin plug, pin 7 --or-- BCM-Dash Fuse Box, black 36 pin plug (J3-C), pin 35
Driver Unlock Motor      Blue/Green      Reverse      Driver Kick, door harness, 8 pin plug, pin 8 --or-- BCM-Dash Fuse Box, black 36 pin plug (J3-C), pin 27
Passenger Unlock Motor      Brown/Green      Reverse      BCM-Dash Fuse Box, black 36 pin plug (J3-C), pin 32
Parking Lights      Green/Orange (LF); Brown/Yellow (RF)      +      BCM-Dash Fuse Box, black 40 pin plug (J6-F), pin 30 (LF); pin 37 (RF)
Parking Lights 2      Blue/Gray (LR/RR)      +      BCM-Dash Fuse Box, black 22 pin plug (J7-G), pin 3
Parking Lights -      Gray      -      Headlight Switch, black 16 pin plug, pin 11           Notes
Parking Lights Interrupt      Black/Blue      Cut      Headlight Switch, black 16 pin plug, pin 4           Notes
Hazards      Brown      -      BCM-Dash Fuse Box, black 52 pin plug (J2-B), pin 19
Turn Signal (Left)      Blue/Green (LF); Gray/Orange (LR)      +      BCM-Dash Fuse Box, black 40 pin plug (J6-F), pin 39 (LF); blue 52 pin plug (J5-E), pin 26 (LR)
Turn Signal (Right)      Yellow/Violet (RF); Green/Orange (RR)      +      BCM-Dash Fuse Box, black 40 pin plug (J6-F), pin 38 (RF); blue 52 pin plug (J5-E), pin 52 (RR)
Headlight      Blue      -      Headlight Switch, black 16 pin plug, pin 12
AutoLights      Green      Cut      Headlight Switch, black 16 pin plug, pin 13
Reverse Light      Green/Brown      +      BCM-Dash Fuse Box, black 22 pin plug (J7-G), pin 19
Left Front Door Trigger      Green/Violet      -      Left Front Door Ajar Switch, white 3 pin plug, pin 1
Left Front Door Trigger 2      Green/Violet (alternate location)      -      BCM-Dash Fuse Box, blue 52 pin plug (J5-E), pin 33
Right Front Door Trigger      White      -      BCM-Dash Fuse Box, blue 52 pin plug (J5-E), pin 21
Left Rear Door Trigger      Green (customer access)      -      BCM-Dash Fuse Box, blue 52 pin plug (J5-E), pin 46
Dome Light      Gray/Violet      +      BCM-Dash Fuse Box, black 36 pin plug (J3-C), pin 13
Tachometer      Blue      AC      Customer Access Harness on driver fender, black 12 pin plug, pin 4
Tachometer 2      White/Green (CMP)      AC      PCM on driver side of engine, 126 pin plug, pin 76
omaga
Posted: April 02, 2022 at 8:23 PM / IP Logged Link to Post Post Reply Quote omaga
Thank you soo much
Thank you all
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
