2003 Chevrolet Duramax, Alarm Wiring
dzerko@yahoo.co
Posted: February 12, 2024 at 3:05 PM / IP Logged Link to Post Post Reply Quote dzerko@yahoo.co
Looking for info on installomg a prestige alarm
David zerko
tonanzith
Gold - Posts: 603
Posted: May 22, 2024 at 6:22 PM / IP Logged Link to Post Post Reply Quote tonanzith
Item     12 Volts
Wire Color     red (40A)
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin F
Photo      Directwire
Note
Item     Second 12 Volts
Wire Color     red/white (40A)
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin B
Photo      Directwire
Note
Item     Ground
Wire Color     (chassis ground)
Polarity
Wire Location
Note
Item     Starter
Wire Color     yellow
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin D
Photo      Directwire
Note
Item     Ignition
Wire Color     pink
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin C
Photo      Directwire
Note
Item     Second Ignition
Wire Color     white
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin E
Photo      Directwire
Note      Notes
Item     Accessory
Wire Color     orange
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin G
Photo      Directwire
Note
Item     Second Accessory
Wire Color     brown
Polarity     +
Wire Location     ignition switch, black 7 pin plug, pin A
Photo      Directwire
Note
Item     R Code
Wire Color     yellow
Polarity     Passlock 2
Wire Location     Passlock sensor on ignition key cylinder
Photo      Directwire
Note
Item     Reference Ground
Wire Color     orange/black or black
Polarity     -
Note
Item     Keysense
Wire Color     lt. green
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin A1
Photo      Directwire
Note
Item     OBD Connector
Wire Color     Black
Polarity
Wire Location     Under Driver Dash, Left of Parking Brake Release
Photo      Directwire
Note
Item     J1850
Wire Color     violet
Polarity     data
Wire Location     OBD-data link connector, black 16 pin plug, pin 2
Note
Item     Power Lock
Wire Color     lt. blue (base models)
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin B5
Photo      Directwire
Note
Item     Power Unlock
Wire Color     white (base models)
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin B10
Photo      Directwire
Note
Item     Power Lock2
Wire Color     (see Tech Doc 1601) (or insert pin) (except base models)
Polarity     -
Wire Location     BCM under driver dash, rear, violet 16 pin plug, pin B3
Note      Notes
Item     Power Unlock2
Polarity     -
Wire Location     BCM under driver dash, rear, violet 16 pin plug, pin B2
Note
Item     Lock Motor
Wire Color     gray
Polarity     5 wire
Wire Location     dash fuse box, black 12 pin plug, pin C (base models); driver window switch, black 26 pin plug, pin 21 (except base models)
Photo      Directwire
Note
Item     Driver Unlock Motor
Wire Color     tan
Polarity     5 wire
Wire Location     dash fuse box, black 12 pin plug, pin F (base models); driver window switch, black 26 pin plug, pin 20 (except base models)
Photo      Directwire
Note
Item     Passenger Unlock Motor
Wire Color     tan
Polarity     5 wire
Wire Location     dash fuse box, rear, black 68 pin plug, pin D11 (base models); passenger window switch, black 26 pin plug, pin 11 (except base models)
Photo      Directwire
Note
Item     Factory Alarm Arm
Wire Color     arms on lock with door open
Polarity
Wire Location
Note
Item     Factory Alarm Disarm
Wire Color     lt. green (key unlock) (except base models)
Polarity     -
Wire Location     driver window switch, black 26 pin plug, pin 15
Photo      Directwire
Note
Item     Disarm No Unlock
Wire Color     see factory alarm disarm
Polarity
Wire Location
Note
Item     Parking Lights
Wire Color     brown (L), brown/white (R)
Polarity     +
Wire Location     underhood fuse box, red 32 pin plug, pins F6 and C6
Note
Item     Parking Lights -
Wire Color     gray/black
Polarity     -
Wire Location     BCM under driver dash, brown 24 pin plug, pin B2
Photo      Directwire
Note
Item     Hazards
Wire Color     white
Polarity     -
Wire Location     hazard switch
Note
Item     Turn Signal (Left)
Wire Color     dk. green
Polarity     +
Wire Location     turn signal switch
Note
Item     Turn Signal (Right)
Polarity     +
Note
Item     Headlight
Wire Color     white
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin A12
Photo      Directwire
Note
Item     AutoLights
Polarity     - (off)
Wire Location     BCM under driver dash, brown plug, pin A8
Photo      Directwire
Note
Item     Reverse Light
Polarity     +
Wire Location     BCM under driver dash, black plug, pin F
Note
Item     Left Front Door Trigger
Wire Color     gray/black (base models)
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin B4
Photo      Directwire
Note
Item     Left Front Door Trigger 2
Wire Color     gray/black (except base models)
Polarity     -
Wire Location     driver window switch, black 26 pin plug, pin 18
Photo      Directwire
Note
Item     Right Front Door Trigger
Wire Color     black/white (base models)
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin A5
Photo      Directwire
Note
Item     Right Front Door Trigger 2
Wire Color     black/white (except base models)
Polarity     -
Wire Location     passenger window switch, black 26 pin plug, pin 5
Photo      Directwire
Note
Item     Left Rear Door Trigger
Wire Color     lt. blue/black
Polarity     -
Wire Location     BCM under driver dash, rear, violet 16 pin plug, pin A3
Photo      Directwire
Note
Item     Right Rear Door Trigger
Wire Color     lt. green/black
Polarity     -
Wire Location     BCM under driver dash, rear, violet 16 pin plug, pin A2
Photo      Directwire
Note
Item     Dome Light
Polarity     +
Wire Location     BCM under driver dash, black plug, pin E
Note
Item     Tachometer
Wire Color     white
Polarity     ac
Wire Location     instrument cluster, gray 24 pin plug, pin A5
Photo      Directwire
Note      Notes
Item     Wait to Start
Wire Color     dk. blue
Polarity     -
Wire Location     instrument cluster, gray 24 pin plug, pin A2
Photo      Directwire
Note      Notes
Item     Clutch Pedal
Polarity     +
Wire Location     clutch switch, black 6 pin plug, pin D
Note
Item     Fuel Pump
Wire Color     gray
Polarity     +
Wire Location     underhood fuse box, red 32 pin plug, pin F1
Note
Item     Rear Defroster
Wire Color     white
Polarity     - latched
Wire Location     BCM under driver dash, gray plug, pin A8
Photo      Directwire
Note
Item     Mirror Defroster
Wire Color     (Class 2 Serial Data)
Polarity
Wire Location
Note
Item     Left Front Heated Seat
Wire Color     dk. blue
Polarity     +
Wire Location     driver window switch, green 12 pin plug, pin 9
Note
Item     Right Front Heated Seat
Wire Color     dk. blue
Polarity     +
Wire Location     passenger window switch, green 12 pin plug, pin 3
Note
Item     Speed Sense
Wire Color     dk. green/white
Polarity     4K
Wire Location     instrument cluster, gray 24 pin plug, pin A4
Photo      Directwire
Note      Notes
Item     Brake Wire
Wire Color     white
Polarity     +
Wire Location     brake switch, black 6 pin plug, pin A
Photo      Directwire
Note
Item     Parking Brake
Wire Color     lt. blue
Polarity     -
Wire Location     BCM under driver dash, lt. blue plug, pin A7
Photo      Directwire
Note
Item     Horn Trigger
Wire Color     black
Polarity     -
Wire Location     BCM under driver dash, gray plug, pin B9
Photo      Directwire
Note
Item     Wipers
Wire Color     pink (L), dk. blue/white (H), gray (ignition)
Polarity     +,-
Wire Location     wiper switch
Photo      Directwire
Note
Item     Left Front Window (Up/Down)
Wire Color     dk. blue - brown
Polarity     C
Wire Location     driver window switch, black 4 pin plug, pins 3 and 1
Note
Item     Right Front Window (Up/Down)
Polarity     C
Wire Location     passenger window switch, black 4 pin plug, pins 4 and 1
Note
Item     Left Rear Window (Up/Down)
Polarity     C
Wire Location     left rear window switch, brown 8 pin plug, pins F and G
Note
Item     Right Rear Window (Up/Down)
Polarity     C
Wire Location     right rear window switch, brown 8 pin plug, pins F and G
Note
Item     Memory Seat 1
Wire Color     red
Polarity     +
Wire Location     driver window switch, green 12 pin plug, pin 10
Note
Item     Memory Seat 2
Wire Color     pink
Polarity     +
Wire Location     driver window switch, green 12 pin plug, pin 5
Note
Item     Radio 12V
Wire Color     orange
Polarity     +
Wire Location     radio harness
Note
Item     Radio Ground
Polarity     -
Note
Item     Radio Ignition
Polarity
Wire Location
Note
Item     Factory Amp Turn-on
Wire Color     pink
Polarity     +
Note
Item     Left Front Speaker (+/-)
Wire Color     tan - gray
Polarity     +,-
Wire Location     radio harness or amplifier under center console
Note
Item     Right Front Speaker (+/-)
Wire Color     lt. green - dk. green
Polarity     +,-
Note
Item     Left Rear Speaker (+/-)
Wire Color     brown - yellow
Polarity     +,-
Note
Item     Right Rear Speaker (+/-)
Wire Color     dk. blue - lt. blue
Polarity     +,-
Note
Gary Sather
Wednesday, July 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
