2017 Toyota Highlander LTD, JBL, +12V Switched For Dash Cam?
upjeeper
Member - Posts: 21
Posted: June 04, 2024 at 9:03 AM / IP Logged Link to Post Post Reply Quote upjeeper
Good morning all,
I've got a 2017 Highlander Limited JBL and would like to be able to tie into a switched / accessory wire for my GPS and dash camera. The SUV does have a push button start
unsure if the small fuse block under the steering wheel has room for a fuse tap or if i should just connect / tap directly into a 12v wire under the steering wheel.
any advice or wiring info please?
thank you
Platinum - Posts: 13,726
Posted: June 04, 2024 at 6:43 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Cigarette lighter or power outlet should be ACC.
Thursday, June 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
