2015 Kia Sedona LX, Backup Camera Wiring?
dustinr
Posted: June 10, 2024 at 9:29 PM / IP Logged Link to Post Post Reply Quote dustinr
I already bought a stereo kit, but im Looking for a pinout for the OEM backup camera specifically, also, does anyone know of a compatible module to do steering wheel controls ?
thanks guys.
dcr
Platinum - Posts: 13,726
Posted: June 11, 2024 at 9:15 PM / IP Logged Link to Post Post Reply Quote i am an idiot
With OEM navigation.
http://metraonline.com/part/AXBUCH6V-HK1
WIthout OEM navigation
http://metraonline.com/part/AXBUCH6V-HK2
The camera is powered with 6 volts. If you do find out the wire colors for the camera you will need a 6 volt regulator. Both of the above items come with the regulator. Much better off investing in the one you need.
dustinr
Posted: June 11, 2024 at 10:20 PM / IP Logged Link to Post Post Reply Quote dustinr
yea unfortunately that's not compatible with my unit, those are for a 16pin cable, or a 24pin cable (with a different layout from mine), mine has the following cables: an 18pin cable, a 24pin cable, a 4pin cable, an xm radio cable, and a regular antenna cable.
I found this wiring diagram online, and it matches my unit exactly (scroll down to the bottom), but the only problem I'm having is discerning which camera wires are signal, and which are power ?
(Camera Vin, Camera battery (+), Camera GND, Camera PGND)?
https://www.kisedona.com/audio_unit_components_and_components_location-1493.html
2015 Kia Sedona LX, Backup Camera Wiring? - Last Post -- posted image.
dcr
Sunday, June 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
