Wire Door Locks Individually
stonecoldtx
Posted: August 24, 2024 at 4:48 AM / IP Logged Link to Post Post Reply Quote stonecoldtx
Hi, All--
I have one of the MES Door Lock kits that comes with the 6-pin 30A MES relay, as a "Central Locking Module", and two 5-wire actuators, and both doors lock/unlock at the same time.
What I would like to do is put both doors on their own separate switches, so that only the Driver or only the Passenger door locks or unlocks at a time, based on which switch is used . . .
Does someone have a wiring diagram I could use to wire up relays to accomplish this?
Thanks in advance!
CutDog504
Silver - Posts: 643
Posted: August 24, 2024 at 5:27 PM / IP Logged Link to Post Post Reply Quote CutDog504
It can be done with two 5 pin relays, but may I ask WHY you want to only lock one door at a time?
Platinum - Posts: 13,714
Posted: August 25, 2024 at 1:44 PM / IP Logged Link to Post Post Reply Quote i am an idiot
This needs to be done on each door
Saturday, July 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
