Voltage Monitoring And Tending For Several Vehicles
burntkat
Copper - Posts: 159
Posted: November 30, 2024 at 12:29 PM / IP Logged Link to Post Post Reply Quote burntkat
I have several vehicles which I don't drive all the time.
I often find a battery is dead when I go to drive a vehicle I haven't driven in a while. I have tried using the Battery Tender in my garage over a long 16ga charge lead to a connector (Anderson Powerpoles) hanging out of the hood. This works, but the human factor screws it up- ie, either I drive away without remembering to unplug (not usually a problem, as the powerpole is easily self-unplugged in this application) or the lead gets run over by the weedeater/lawnmower when the wife or kid decide to cut the grass.
Honestly, there's an easy fix for that as well- but I'd rather have something standalone....
What I am looking for is something like a remote start, but without the remote. I want a system that will monitor the battery's voltage, and start when it gets to, say, 11 volts.
I know there is a feature like that in the Bitwriter menu on DEI remote starts, but given issues with DEI having locked down their accounts about 10 years ago, I doubt I have the ability to just buy a BitWriter and do it myself. Plus, the local shops in this area... well, let's just say they don't fill me with a warm fuzzy feeling as to their employees. (This is totally on me, I am not accusing anyone of anything. But at the same time, I am aware that things do happen)
Obviously the autostart feature of a remote start would be ideal. At the same time, I want the ability to disable the autostart feature entirely (say, maybe I am working under the hood, or I'm going to be out of town a while and don't want vehicles starting up unattended..
Plus, there's the obvious need to interface with an alarm in order to prevent it going off.
I have even considered just installing a solar panel on the roof to keep the battery topped off. I haven't pulled numbers re: parasitic drain and charge capacity of a reasonable panel....
Surely I can't be the only nut that's ever thought of this?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it. - Robert A. Heinlein"
lee.lopez
Copper - Posts: 340
Posted: December 02, 2024 at 7:48 PM / IP Logged Link to Post Post Reply Quote lee.lopez
I never used it, but I liked that feature on the Vipers. You can still DIY install them from online sellers.
I do like the Bitwriter, too.
Maybe you can find a voltage monitor with a low voltage alarm and use that to trigger a remote start.
itskamel
Member - Posts: 14
Posted: January 26, 2025 at 12:48 AM / IP Logged Link to Post Post Reply Quote itskamel
Same here, I put a note on my steering wheel to disconnect the charger.
Monday, November 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
