1992 Nissan 240SX, Power Window Diagram
w0010
Posted: January 26, 2025 at 1:16 PM / IP Logged Link to Post Post Reply Quote w0010
Okay to start, Sorry if this is in the wrong forum.
I have a 1900 240SX that I am wiring from the ground up and I would like to use the power switch from the convertible in the center console to control the power Windows. The only problem is that the switch meters out as a NCHO and I'm not sure how to make this work correctly. According the the 92 240SX Convertible annex this is how the switch wires up from factory.
White - Relay, Side Window Lock Out(Constant)
Green - Right Up
Red    - Right Down
Blue   - Left Up
Yellow - Left Down
White / Black   - Power Window Amplifier
I searched 240SX, NCHO power Windows, Negative trigger power windows (This came back with some info, but I couldn't figure out how to make it work), and I dug through the Relay diagrams, though I could have not recognized the correct name for what I am looking for.
John
w0010
Posted: January 26, 2025 at 1:44 PM / IP Logged Link to Post Post Reply Quote w0010
So After I posted I looked at the 3 wire positive trigger door locks. If I'm not mistaken I can wire the switch legs to the "alarm (-) lock output" and the "positive lock / unlock wire" to the power window motor. Am I wrong in this?
Saturday, June 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
