Should i buy these?
hawaiianalii
Posted: June 13, 2003 at 1:17 AM / IP Logged
its me again and im still wondering if i should buy these subs they are 69.99$ on ebay and shipping is 50 bucks.  i am thinking about getting two.  if you wanna see them, go here http:///.com/ws/ebayisapi.dll?viewitem&item=3028719896&category=18804. here are some specs:
brand new 15" 1200 watt volfenhag competition subwoofer
  • red aluminum cone to eliminate distortion at high volume levels
    bumped and vented chrome t-yoke
  • high temperature 4 layer voice coil
  • voice coil cooling ventilation system
  • double damper
  • heavy duty screwed together industrial magnet structure
  • vented magnet structure
  • push button terminals
  • competition quality!!!!
  • double stacked chrome magnet with 2 sets of professional inputs, check out the cooling vents on the magnets motor and voice coil. die cast ridged frame
  • designed to work well in a vented, sealed or bandpass box
  • red aluminum die cast basket
  • dual 4 ohm voice coil
  • 2 ohm / 4 ohm / 8 ohm operation
  • efficiency ( 1w/1m) 91.00
  • re dc resistance 3.2 ohm
  • imp dual 4 ohm
  • power handling continuous 600 watt
  • mounting depth 7.3 inches
  • mounting diameter 14.17 inches
  • sd piston surface area 3.36"
  • fs 29hz
  • qts 0.670
  • qes 0.8062
  • qms 3.9648
  • vas 116 l
  • weight is 26 lbs. each subwoofer
  • Big Purds
    Silver - Posts: 574
    Posted: June 13, 2003 at 3:45 AM / IP Logged
    youd be better off taking that money and spending it in the bar for the amount of actual enjoyment you would get out of them...
    chasesaccessori
    Copper - Posts: 198
    Posted: June 13, 2003 at 8:03 AM / IP Logged
    I think what Big Purds should have said is: Be very careful about electronics you purchase on the net.   If something is wrong with them, how will the seller deal with the problem. Probably wont.
    Platinum - Posts: 12,488
    Posted: June 13, 2003 at 8:15 AM / IP Logged
    I agree with both of the comments above. With you being in Hawaii and the fact that if you have any problems with the subs ( which you most likely will ), you won't want to ship them back and forth to the sellernecause of cost of shipping. Stick to a good brand name company with a well rounded reputation. Chances are you won't have any problems with them and it will last you years instead of months.
    audioconnection
    Member - Posts: 45
    Posted: June 13, 2003 at 8:51 AM / IP Logged
    along the same lines as the last posts, your gonna get no luck at all if there is a problem with them, if you want a decent sub low budget sub for the same money look for pyramid, i know the name isnt looked well upon but the subs your looking at are sold in the UK and are about the same thing as pyramid only thing is you can find a dealer who sells them anywhere and they are good about warranty problems.
    remember...Friends Dont let friends Install, Take it to a pro..
