2003 safari door locks
rickgood
Member - Posts: 38
Posted: June 15, 2003 at 10:53 AM / IP Logged
i am looking at installing a clifford in this 2003 safari.everything looks straight forward except the door locks. do i splice my wires directly at the door lock module and will it interfere with the bcm.
draasch
Gold - Posts: 2,172
Posted: June 16, 2003 at 4:15 AM / IP Logged
Make:   GMC
Model: Safari
Year:    2003
This Database Was Last Updated On:    6/9/03
Index #: 7669
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) BELOW FUSEBOX IN WHITE CONNECTOR
Trunk Pin Switch
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock LIGHT BLUE AT DOORLOCK RELAYS #202
Power Unlock WHITE IN PASSENGER KICK PANEL
#202 See Positive Pulse Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
