Which do you suggest......
Greenmachine
Member - Posts: 10
Posted: June 16, 2003 at 8:09 PM / IP Logged
I have 2 choices...... use my current uninstalled component set which is a Cerwin Vega SS6.2 (6.5") or step down to a 5.25" component set? Reaso why i ask is with the 6.5" set i'll more than likly have to do some minor surgery to the inner door panel if i go with the larger set versus just a simple adaptor kit.
Amp to power this is my Phoenix Gold QX4150 amp...... 50w rms x 4
Which do you suggest...... - Last Post -- posted image.
Silky smooth and rockin hard
Ecotec power
luxuryrules
Copper - Posts: 102
Posted: June 17, 2003 at 8:38 AM / IP Logged
The main difference you're looking at is the 6.5s will be able to handle the lower frequencies better.  If you have any subwoofers, or even just 6x9s or 6.5s in the back then you will be ok stepping down.  However, if you've got like 5.25s all around, then I would just take the time to custom fit the 6.5s.  Just my opinion.
I refuse to tiptoe through life only to arrive safely at death.
bberman1
Gold - Posts: 2,314
Posted: June 17, 2003 at 9:24 AM / IP Logged
I would take the time and do the modification if it meant better sound in the end.
Greenmachine
Member - Posts: 10
Posted: June 17, 2003 at 6:21 PM / IP Logged
System at prestsent time will consist of....unfortunatly running off stock headunit for now
-Cerwin Vega SS6.2 Component set..... Single Sony 10" Xplod sub..... Phoenix Gold QX4150 amp (50x2+150x1)
Ecotec power
bberman1
Gold - Posts: 2,314
Posted: June 18, 2003 at 9:26 AM / IP Logged
Sounds good!
luxuryrules
Copper - Posts: 102
Posted: June 18, 2003 at 9:00 PM / IP Logged
Just the Cerwin Vegas providing sound on the interior?  I wouldn't step down.
Greenmachine
Member - Posts: 10
Posted: June 19, 2003 at 6:55 PM / IP Logged
Well eventually i wanna upgrade the rear 6x9's and get a deck that is mp3 compatible.
The 6.5" will be alone in the door and the .75" tweeter will be in the factory sail panel hopefully
Ecotec power
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
