1999 Isuzu Amigo Alarm/RMT Start Diagram
gjones77
Member - Posts: 29
Posted: June 28, 2003 at 9:43 PM / IP Logged
I just need the wiring diagram for a 1999 Isuzu Amigo so I can install a remote start/Alarm system. I believe it's the same as a 2000 but I want to be safe. Thanks so much
Moderator - Posts: 12,488
Posted: June 28, 2003 at 9:49 PM / IP Logged
|              12V|white, WHITE/ black  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ red       |-  |DKP white 22 pin connector  |
|     POWER UNLOCK|RED / blue            |-  |DKP white 22 pin connector  |
|       LOCK MOTOR|blue/red            |+  |drivers door harness        |
|     UNLOCK MOTOR|blue/white          |+  |drivers kick panel *1       |
|    DISARM DEFEAT|blue                |+  |passenger kick panel *2     |
| PARKING LIGHTS +|GREEN/ red           |   |drivers kick in a black plug|
| PARKING LIGHTS -|yellow or grn/yel   |   |steering column             |
|       HEADLIGHTS|red or RED / blue     |-  |steering column             |
|     DOOR TRIGGER|RED / green           |-  |drivers kick in a white plug|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|GREEN/ red           |-  |keyless module *3           |
|TRNK/HTCH RELEASE|lt. green           |   |keyless module *3           |
|  FCTRY ALARM ARM|purple *5           |-  |drivers kick in a white plug|
|FCTRY ALRM DISARM|yellow/blue *5      |-  |drivers kick in a white plug|
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ red           |   |dkp, blk 22 pin plug, pin 4 |
|      SPEED SENSE|blue/black          |   |dkp, blk 22 pin plug, pin 2 |
|       BRAKE WIRE|red                 |+  |brake switch                |
|     HORN TRIGGER|green               |-  |steering column             |
|           WIPERS|blu/yel & blu/wht   |+  |steering column             |
|  LF WINDOW UP/DN|brn/wht - brn/red   |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - brn/red   |A  |RF window switch            |
| SUN RF OPN/CLOSE|purple - blue       |A  |sunroof motor *4            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|RED / white           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / yellow          |+  |radio                       |
| RADIO ILLUMINATE|GREEN/ red           |+  |radio                       |
|       LF SPEAKER|blue - yellow       |   |radio or speaker            |
|       RF SPEAKER|green - gray        |   |radio or speaker            |
|       LR SPEAKER|orange - white      |   |radio or speaker            |
|       RR SPEAKER|orn/blu - orn/wht   |   |radio or speaker            |
Notes:
*1 In a white 10 pin connector  *2 Located up high in a white connector  *3 The keyless module is located above the passenger kick panel.  *4 The sunroof motor is located in front of the sunroof in the headliner.  *5 Trigger the power lock and the factory alarm arm wires at the same time to arm the alarm.  Trigger the power unlock and the factory alarm disarm wires at the same time to disarm the alarm.
gjones77
Member - Posts: 29
Posted: June 28, 2003 at 10:16 PM / IP Logged
I can't thank you enough, you guys are great
Posted: June 29, 2003 at 8:12 AM / IP Logged
No problemo
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
