Wiring diagram for 2001Nissan Sentra 4-do
Paddypaws
Posted: June 28, 2003 at 11:30 PM / IP Logged
 Peoples: I am looking for a wiring diagram for a 2001 Nissan Sentra 4-door with a factory installed door locks and trunk release. I want to install an aftermarket alarm.Any suggestions out there.
Paddy
Platinum - Posts: 12,488
Posted: June 29, 2003 at 8:15 AM / IP Logged
|              12V|WHITE/ red           |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|   SECOND STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|white               |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ blue          |+  |ignition harness            |
|       POWER LOCK|gray                |-  |Time Control Unit or SECU *1|
|     POWER UNLOCK|PURPLE / red          |-  |Time Control Unit or SECU *1|
|       LOCK MOTOR|RED / black           |   |pin 15 at SECU *1           |
|     UNLOCK MOTOR|blue/red            |   |pin 13 at SECU *1           |
|    DISARM DEFEAT|WHITE/ red           |   |pin 14 at SECU *1           |
| PARKING LIGHTS +|wht/red or RED / blu  |   |headlight switch or DKP     |
| PARKING LIGHTS -|org/blk   (hazards) |   |pin 7 at SECU *1            |
|       HEADLIGHTS|RED / yel(L), purple(R|+  |headlight switch            |
|     DOOR TRIGGER|*2                  |-  |*2                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|RED / black *3        |-  |trunk light or SECU *1      |
|         HOOD PIN|pink/black          |-  |hood switch or SECU *1      |
|TRNK/HTCH RELEASE|red                 |-  |release switch *4           |
|  FCTRY ALARM ARM|lt. GREEN/ red       |-  |pin 41 at SECU *1           |
|FCTRY ALRM DISARM|WHITE/ blue          |-  |pin 30 at SECU *1           |
|       TACHOMETER|*5                  |   |*5                          |
|      SPEED SENSE|PURPLE / red          |   |instrument cluster          |
|       BRAKE WIRE|RED / green           |+  |brake pedal switch          |
|     HORN TRIGGER|WHITE/ green         |-  |steering column or SECU *1  |
|           WIPERS|grn/red(L),grn/wht(H|-  |steering column             |
|  LF WINDOW UP/DN|grn/red - blue      |A  |drivers window switch       |
|  RF WINDOW UP/DN|RED / wht - red       |A  |drivers kick panel          |
|  LR WINDOW UP/DN|yellow - yel/blk    |A  |drivers kick panel          |
|  RR WINDOW UP/DN|grn/wht - green     |A  |drivers kick panel          |
|        RADIO 12V|blue                |+  |at radio                    |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|pink                |+  |at radio                    |
| RADIO ILLUMINATE|yellow/red          |+  |at radio                    |
|       LF SPEAKER|purple - grn/yel    |   |at radio                    |
|       RF SPEAKER|brown - brn/wht     |   |at radio                    |
|       LR SPEAKER|orange - blk/pnk    |   |at radio                    |
|       RR SPEAKER|gray - gry/red      |   |at radio                    |
Notes:
NOTE: Some models have an immobilizer system that needs to be bypassed during remote start.  Use DEI module 555U to bypass.  *1 The Time Control Unit or the SECU (smart entrance control unit) is to the right of the steering column.  *2 On vehicles without power doorlocks use RED / white in the drivers kick panel.  Vehicles with power doorlocks use red for the drivers door and RED / white for the passenger doors, at the Time Control Unit or SECU.  *3 On models without the SECU, have to diode isolate the trunk pin wire from the trunk light to avoid falsing problems.  *4 Can also use pink/black in pin 12 at the SECU but it is high current negative, and must use a relay.  *5 For tach go to any of the coils and use one of the following: BLACK/ red, purple, blue/red, or gray/red.  Can also use blue/orange at the instrument cluster if vehicle is equipped with a tachometer.
