2002 Honda Accord Alarm/Remote Start
undergraduate
Member - Posts: 9
Posted: July 06, 2003 at 9:17 PM / IP Logged
I have been asked to install a remote start/alarm on a 2002 honda accord 4cyl and I cannot find any of the wiring diagrams for the car.  Plus, the car has a factory alarm system.  Should I disable it or use it with the new alarm?  And is there some sort of transponder in the key that I need to bypass?  Any info would really help, thanks.
profuse007
Gold - Posts: 2,015
Posted: July 06, 2003 at 9:40 PM / IP Logged
12 VOLTS CONSTANT   WHITE   IGNITION SWITCH HARNESS
IGNITION 1   BLACK / YELLOW   IGNITION SWITCH HARNESS
IGNITION 2   YELLOW   IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER   WHITE/ BLACK   IGNITION SWITCH HARNESS
STARTER   BLACK/ WHITE   IGNITION SWITCH HARNESS
PARKING LIGHTS   RED / BLACK ( + )   @ FUSEBOX ON DRIVERS SIDE
DOMELIGHT   BLACK/ WHITE ( - )   @ FUSEBOX ON PASS. SIDE
PWR DOOR LOCK   BLACK/ BLUE ( - )   @ FUSEBOX ON PASS. SIDE
PWR DOOR UNLOCK   ORANGE ( - )   TYPE B (EX green 20 pin conn/LX 2 pin gray conn driver fuse box)
TRUNK RELEASE   WHITE/ RED ( + )   DRIVERS KICK PANEL
TACH SENSOR   BLUE (-) 4cyl-behind batt/v6-strut tower)
BRAKE   WHITE/ BLACK ( + )   @ BRAKE PEDAL SWITCH
FACTORY DISARM   DISARMS with UNLOCK    (EX at the door/ LX at the unit under dash)
FACTORY ANTI-THEFT   TYPE   TRANSPONDER 555h or 555u
undergraduate
Member - Posts: 9
Posted: July 07, 2003 at 10:28 PM / IP Logged
Could I get a clarification as to where the pwr door unlock is located. (TYPE B???)  And is there any sort of factory hood pin?  Thanks, this info is worth a million bucks, you guys rock.
profuse007
Gold - Posts: 2,015
Posted: July 08, 2003 at 10:39 AM / IP Logged
type b is just a negative pulse use in many of japs car.
the power dlocks of is on the passenger side, its not a fuse box its just whole bunch of wire harness plugs. its locate b/t the door or right/lower of the a/c duct/vent. in a green 20 pin connector.
HOOD PIN|yellow/red or yellow(-)On the EX models it is in a green plug next to the passenger side fuse box. On the LX models it is at the keyless/security unit, if equipped, which is attached to the driver side underdash panel.
what model car is this+ what brand alarm?
Houston,TX
undergraduate
Member - Posts: 9
Posted: July 11, 2003 at 1:20 AM / IP Logged
I don't know it the car is an EX or LX, I just know it is a 02 Accord with a 4cyl.  The alarm/remote start is going to be a crimestopper cs-2011rs or a crimestopper cs-2015fm.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
