alarm sounds when plugged up
bigt_45
Copper - Posts: 48
Posted: July 07, 2003 at 8:02 PM / IP Logged
I have an american accessories alarm with keyless entry.  its not a name brand alarm, but it has all the essentials.  i put it in my 88 camaro and i am pretty sure i wired everything up right.  i even hooked up the a 3 wire positive trigger and a starter disable relay.  when i plug the module up, the alarm sounds continuously and the parking lights flash (as if the alarm had been set off) does anyone have any suggestions?
padawan
Copper - Posts: 215
Posted: July 07, 2003 at 8:04 PM / IP Logged
Some alarms do that when u first install it, what u gotta do is turn it off, this is usually done by putting the key, setting the ignition to ON, and pressing and holding the valet override button for 5-10 secs til it goes off...
That should do it.
bigt_45
Copper - Posts: 48
Posted: July 07, 2003 at 8:20 PM / IP Logged
okay, thank you!!!   that worked, and i programmed my transmitter.  the car arms and disarms fine.  the panic button works.  the doors do not lock or unlock and the trunk will not open with the transmitter.  Now what is wrong?
padawan
Copper - Posts: 215
Posted: July 07, 2003 at 9:59 PM / IP Logged
make sure u've got ur trunk pop output wire or aux output wire from ur alarm going to the black wire in the driver's kick...make sure u test that wire 1st...if ur using an aux output that does not have it's own button on ur remote, try holding the button (that does not trigger panic mode) down for a few secs see if it pops ur trunk then.
As for the door locks, just make sure u got it rigged up right with the relays...check and double and triple check...
Try http://www.relayapps.com for diagrams.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
