2001 jeep wrangler se diagram
asjeep
Member - Posts: 22
Posted: July 11, 2003 at 10:41 AM / IP Logged
anyone have this one? is a 2.5l 4cyl engine
thanks
Aaron
Rams Z
Member - Posts: 14
Posted: July 11, 2003 at 6:13 PM / IP Logged
found this for you hope this helps. Found it from a website called bulldogsecurity.com
WRANGLER 2000- 2003 Printer Friendly Version
WIRE COLOR LOCATION
12 VOLTS CONSTANT  PINK/BLACK and RED  IGNITION SWITCH HARNESS
IGNITION 1  BLUE  IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1  BLACK/ ORANGE  IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2  BLACK /GREEN  IGNITION SWITCH HARNESS
STARTER  YELLOW  IGNITION SWITCH HARNESS
PARKING LIGHTS  BLACK / YELLOW ( + )  @ LIGHT SWITCH
DOMELIGHT  YELLOW ( - )  @ LIGHT SWITCH
PWR DOOR LOCK  N/A
PWR DOOR UNLOCK  N/A
TRUNK RELEASE  N/A
TACH SENSOR  GRAY  @ COIL (2.5L) or COIL PACK (4.0L)
BRAKE  WHITE/ TAN  @ BRAKE PEDAL SWITCH
HORN  RED / YELLOW ( - )  @ STEERING COLUMN
FACTORY DISARM  N/A
FACTORY ANTI-THEFT  N/A
PLEASE NOTE: If the last line in the above chart contains an entry - FACTORY ANTI THEFT and its value is Passlock1, Passlock2, Vats or Transponder, you have to buy the bypass module 791. Please click here - Part 791
