Remote entry system 1992 Toyota Celica
harddrive
Posted: July 19, 2003 at 11:10 AM / IP Logged
I would like to install a remote entry system on my 92 Toyota Celica.    Can anyone help me with locating the wiring for the power locks.
dellenbu
Platinum - Posts: 12,488
Posted: July 19, 2003 at 2:03 PM / IP Logged
|              12V|white or BLACK/ red  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|blue/red            |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|gray                |+  |ignition harness            |
|       POWER LOCK|blue/black          |-  |drivers kick panel          |
|     POWER UNLOCK|blue and green *2   |-  |drivers kick panel          |
| PARKING LIGHTS +|dk. green           |   |drivers kick panel          |
| PARKING LIGHTS -|lt. green           |   |steering column             |
|       HEADLIGHTS|RED / yellow          |-  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |fuse box                    |
|  TRUNK/HATCH PIN|RED / white *3        |-  |trunk light                 |
|       TACHOMETER|black or WHITE/ blue |   |check connector *1          |
|       BRAKE WIRE|GREEN / WHITE         |+  |drivers kick panel          |
|     HORN TRIGGER|green               |-  |steering column             |
|           WIPERS|blue/orange         |+  |steering column             |
|  LF WINDOW UP/DN|green - red         |A  |drivers door switch         |
|  RF WINDOW UP/DN|grn/wht - RED / blu   |A  |drivers kick panel          |
Notes:
*1 The check connector is located just behind the drivers shock tower.  *2 Use both wires and diode isolate each.  *3 Tied in with door trigger on hatchback models.
harddrive
Posted: July 20, 2003 at 12:01 PM / IP Logged
That looks like what I need.  Thanks for the help.
dellenbu
Posted: July 20, 2003 at 12:06 PM / IP Logged
No problemo
Sunday, May 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
