door locks 03 stratis
mkyriss
Member - Posts: 9
Posted: July 22, 2003 at 9:11 AM / IP Logged
need info onhokken up door locks
were to find an what 2 do
draasch
Gold - Posts: 2,172
Posted: July 22, 2003 at 9:32 AM / IP Logged
tghis is what i have for the 2000. not sure if it will work for you. double check the wires first....
Make:   Dodge
Model: Stratus
Year:    1999-00
This Database Was Last Updated On:    6/9/03
Index #: 8712
Alarm
Constant 12 volts RED, RED / BLU, PNK/BLK IGNITION SWITCH HARNESS *
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) BLK 6 PIN CONN. AT JUNCTION BLOCK **
Trunk Pin Switch TAN/BLACK (-) AT LIGHT IN TRUNK
Parking Lamp BLACK / YELLOW (+) AT HEADLIGHT SWITCH ***
Power Lock SINGLE WIRE SYSTEM BROWN 16 PIN CONNECTOR #217
Power Unlock WHITE/ D GREEN **** IN DR. KICK PANEL
* !!CAUTION!! The RED / L BLUE Wire Is Only Fused At 10 Amps. The RED Wire Is Only Fused At 20 Amps. The PINK/BLACK Is Fused At 40 Amps. ** Junction Block Located Behind Left Side Of Driver Dash. *** Also Located At The Steering Column Harness
Single Wire Door Lock System, WHITE/ GREEN Wire Requires A 12 VDC (+) Pulse Thru A 620 Ohm Resistor To Lock And A 12 VDC (+) Pulse Thru A 2.7K Ohm Resistor To Unlock.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
