Chrysler Pacifica wiring?
tom small
Member - Posts: 36
Posted: July 22, 2003 at 8:12 PM / IP Logged
Already had 3 or 4 customers ask for remote starts on their Chrysler Pacificas.
Anyone have wiring info?
Thanks...
draasch
Gold - Posts: 2,172
Posted: July 23, 2003 at 1:44 PM / IP Logged
Make:   Chrysler
Model: Pacifica
Year:    2004
This Database Was Last Updated On:    6/9/03
Index #: 9960
Alarm
Constant 12 volts PURPLE / RED CONN. C1 AT BCM *
Ignition 12 volts PINK/GRAY IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light
Trunk Pin Switch
Parking Lamp COLOR N/A AT BCM *
Power Lock PURPLE / LT BLUE IN DRIVER'S DOOR #217
Power Unlock SAME AS LOCK SINGLE WIRE SYSTEM **
* BCM Located In Driver's Kick Panel ** PURPLE / LT BLUE Wire Must See Chassis Ground Through A 1780 Ohm Resistor to Lock/Arm And Chassis Ground Through A 720 Ohm Resistor To Unlock Driver's Door/Disarm. Use Double Pulse To Unlock All Doors. #217 - See Single Wire Resistor Doorlock Circuit Diagram !!Information Courtesy Of Installer, Additional Information Appreciated!!
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
