530t window problems
sufferrar
Copper - Posts: 190
Posted: July 28, 2003 at 8:05 AM / IP Logged
I did a 4 window rool up/down using 2 530t .sometimes teh back doesnt respond when going down until the front goes down first . but most of the times the back will only respend when the front the about half way down . both are tied to the 4th channel .. when armed all windows goes up at the same time ...the only problem is when the windows have to go down when i trigger the channel ... the front will always respend first .. the dip switches on the module has been set on high for the 2 modules - it works best this way ...i tried oiling the grooves for the windows but this wouldn't help much since the windows goes up easily but gives problems going down . the relay clicks in the module when triggered so i know that the connections are good ...help ...
"I'm So Loud It Hertz"
cpgoose
Gold - Posts: 1,098
Posted: July 28, 2003 at 8:10 AM / IP Logged
Did you try switching the two modules just to eliminate that as an option? Maybe it's just the fact that it takes longer for the current to reach the rear windows. In my car, the driver's side responds before the passenger side window does.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
sufferrar
Copper - Posts: 190
Posted: July 28, 2003 at 8:18 AM / IP Logged
Now that you mention it , my front passenger window responds before the driver since the module is located closer the the passenger and the wire route is shorter there.
The back has a much longer route but the power is taken directly from the battery so there should be not power problem there.
i haven't switched the modules-it will take me some time to do this ...
i notice the relay click always when i trigger it but some times there are no respose ... overall it does what i want it to do . thanks ....
cpgoose
Gold - Posts: 1,098
Posted: July 28, 2003 at 8:23 AM / IP Logged
Yea, like I said, my driver's window responds first...and my module is located closer to that door than the passenger door (I see a pattern here). I didn't wire the power to the battery, just under the dash. I used pretty thick wire to go into the doors, though, something like 10 or 12 awg I think.
By the way, where'd you get your 530t? I'm looking to buy another for the sunroof.
sufferrar
Copper - Posts: 190
Posted: July 28, 2003 at 8:24 AM / IP Logged
Hey do you need to disable the antigrind from the alarm when armed to properly roll down the window .. i have checked it with antigrind on and off and i didn't see any difference ......
cpgoose
Gold - Posts: 1,098
Posted: July 28, 2003 at 8:34 AM / IP Logged
Yea, I disabled mine just because the manual said to. No, I didn't see any difference, though.
Where'd you get your 530t?
sufferrar
Copper - Posts: 190
Posted: July 28, 2003 at 8:59 AM / IP Logged
My cousin got mine from somewhere in NYC . not to sure where he got it . it came with a hornet554t ...it could be one of the target stores ...
