RMS In Parallel
DjIQ
Copper - Posts: 107
Posted: July 28, 2003 at 1:04 PM / IP Logged
If i wire (3) subs in parallel, will the rms be equal to the sum of the 3 woofers, or with the rms remain equal to that of one sub?
bberman1
Gold - Posts: 2,314
Posted: July 28, 2003 at 3:04 PM / IP Logged
The RMS will be equal to the 3 subs combined. So if you had (3) 300 watt subs you would have a total of 900 watts rms. and you would need a 900 watt amp to push them. But you must also make sure that the independence of the subs wired in parallel doesn’t exceed the capabilities of the amp.
Special-K
Member - Posts: 43
Posted: July 29, 2003 at 11:38 PM / IP Logged
Exactly. Make sure u wire it CORRECTLY. Get a good amp.
My philosphy is: As long as you have a good amp, subs are irelevant.
wvsquirrel
Gold - Posts: 1,237
Posted: July 29, 2003 at 11:45 PM / IP Logged
Special-K, you might want to re-think that philosophy. Even though having a good amp with minimum distortion (clean signal) is essential to any system, matching it with the same or better quality subs is also essential. Saying "subs are irelevant" as long as you have a good amp is like saying "I put 103 octane in my Pinto so it should be able to run 9's in the quarter!"
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
tdsteele
Silver - Posts: 393
Posted: July 30, 2003 at 1:39 AM / IP Logged
lmao.....good one squirrelRMS In Parallel -- posted image.
