alarm wiring diagram for Peugeot 206 please!
Faraz
Posted: March 28, 2002 at 6:55 AM / IP Logged
who has Peugeot 206 wiring diagram? please send me by mail or here...
MajorFaraz@Yahoo.com
dbxcompany
Posted: March 28, 2002 at 2:05 PM / IP Logged
There are some differences between wiring diagrams depending on PETROL or DIESEL and if there is original remote control.
Here I'm giving you wiring diagram of Peugeot 206 PETROL with original remote control.
Power Supply : +30 connect to the 3 mm wire, at the position nr. 2, of the 2 way black connector coming out of the front part of the BSI operating central.
Ignition Wire : + 15/54: connect to the wire at the position nr. 14 of the 16 way grey connector.
Direction Indicators : Connect to the wires at the positions nr. 13 and nr. 14 of the 16 way black connector.
Immobilisation point : Cut the VIOLET wire, at the position nr. 9 in the 16 way black connector located behind the left lateral bulkhead, driver’s side.
Starter : +50 Cut the BLUE wire located in the wiring harness coming out of the connector of the ignition key.
Door Switch : Connect to the wire, at the position nr. 32 of the green connector, inside the connection with white covering, in the fuse box. Note: The lamp polarity is positive.
Additional info :
Central door locking : Cut the WHITE wire, at the position nr. 15 (unlock) and the GREY wire located at the position nr. 13 (lock) located in the wiring harness coming out of the 16 way grey connector.
P.S. Good luck..
dbx@mail.bg
Faraz
Posted: April 06, 2002 at 4:12 AM / IP Logged
Hi, and thanks for your information.... unfortunately I installed the Alarm by an additional actuatore in driver's door! because I couldn't find the wright wires for central lock module! anyways thanks again...
Faraz
FarPak
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
