two 4ohm Xplod 12''s and 2ohm stable amp
JPHill
Member - Posts: 9
Posted: July 30, 2003 at 11:00 PM / IP Logged
how do i wire the subs to get the most power out of the amp? it is a Power Acoustik Fire & Ice 820watt amp. i also have a Autotek 12'' SS that i might hook up but i dont know it is 8ohms. any help on this install would be greatly appreciated.   two 4ohm Xplod 12''s and 2ohm stable amp - Last Post -- posted image.
JPHill
wvsquirrel
Gold - Posts: 1,237
Posted: July 30, 2003 at 11:10 PM / IP Logged
What's the model number of the Power Acoustik amp, and the model number of the 12's?
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
JPHill
Member - Posts: 9
Posted: July 30, 2003 at 11:56 PM / IP Logged
the amp is FI820 or something like that and the subs are XL1235's, and i aint too old for loud music , im 18 LOL
wvsquirrel
Gold - Posts: 1,237
Posted: July 31, 2003 at 12:20 AM / IP Logged
Power Acoustik FI2X-820
200 x 2 @ 4ohms
250 x 2 @ 2ohms
500 x 1 @ 4ohms mono/bridged
Sony Xplod XS-L1235
4ohm SVC
200 RMS
800 Peak
Safest wiring configuration
Your safest way is to wire each sub to its own channel. You will receive the 200 x 2 @ 4ohms rating (each sub will receive apx 200 watts). This is actually the "ideal" match for your subs.
Try at your own risk
Your amp is only listed at 4ohms Mono stable. If you bridged both subs you would present a 2ohm mono load on the amp. Some amps can handle a 2ohm mono load (even if the specs don't state it), some can't. If you try this way, start with the Gains turned All The Way Down (counter-clockwise), and then slowly increase them. If the amp starts shutting off on its own or you get alot of distortion, then immediately revert to 1 sub per channel. You may damage the amp and/or subs in the process though, so be warned (clipping is never a good thing for an amp to do). If it works, you would get at least 500 watts total, 250 watts per sub.
LMAO!!! And don't worry, I've got 10 years on you and I'm still not too old for loud music two 4ohm Xplod 12''s and 2ohm stable amp - Last Post -- posted image.
Squirrel
JPHill
Member - Posts: 9
Posted: July 31, 2003 at 12:29 AM / IP Logged
well thanks alot ur alot of help buddy. sh*t u even looked up all the specs. i added u to my buddy list
LOLtwo 4ohm Xplod 12''s and 2ohm stable amp - Last Post -- posted image.
wvsquirrel
Gold - Posts: 1,237
Posted: July 31, 2003 at 12:56 AM / IP Logged
no prob. glad to help
Squirrel
