03 Silverado Speed Sensor Wire?
Jack Daniels
Member - Posts: 13
Posted: July 31, 2003 at 11:17 AM / IP Logged
Does anyone know where I might be able to locate the factory speed sensor wire for our NAV unit?
J.D.
DanDan
Copper - Posts: 125
Posted: July 31, 2003 at 5:44 PM / IP Logged
In the convenience center under the drivers dash or behind the instrument cluster
DanDan
Jack Daniels
Member - Posts: 13
Posted: July 31, 2003 at 6:11 PM / IP Logged
I found it, I popped out the gauge cluster, disconnected the cluster, drove around for about 5 minutes with the DMM, and found it, GREEN/ White stripped wire.
J.D.
djfearny2
Silver - Posts: 810
Posted: July 31, 2003 at 7:11 PM / IP Logged
thats it also found at the ecm in the engine. along with the reverse wire. which is needed if your using navigation.
Jon
Installer/Help Technician
---coral springs florida---
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
