2003 kia spectra door wire
prgxj220
Posted: July 31, 2003 at 9:09 PM / IP Logged
Need help finding the common wire for all the door pins on a 2003 Kia Spectra.  Have isolated all the individual wires but thought I would ask before wiring diodes.  Thanks in advance.
Paul
mobiletoys2002
Gold - Posts: 1,050
Posted: July 31, 2003 at 9:42 PM / IP Logged
have you thought about using the wire that turns on the domelight?? this may be easier than doing all that.
draasch
Gold - Posts: 2,172
Posted: August 01, 2003 at 4:54 AM / IP Logged
this is all the info that i have.....
Make:   Kia
Model: Spectra
Year:    2003
This Database Was Last Updated On:    6/9/03
Index #: 1647
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts WHITE/ BLUE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) DRIVERS DOOR SWITCH
Trunk Pin Switch GREEN/ YELLOW (-) DRIVERS KICK PANEL
Parking Lamp PINK/BLACK (+) DRIVERS KICK PANEL
Power Lock
Power Unlock
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Laur
Copper - Posts: 65
Posted: August 02, 2003 at 5:36 PM / IP Logged
try on gtalarm.it
