Pioneer DEH-P3500
KiDFuZioN
Member - Posts: 18
Posted: August 02, 2003 at 1:47 AM / IP Logged
I need help with a wire. On the pioneer headunit there is a ORANGE / white wire that has the words "ill" on it. Do I connect this wire to the illumination wire on my car or the dimmer wire. I think it goes to the illumination wire on my stock radio harness but am not sure.
noob
Copper - Posts: 92
Posted: August 02, 2003 at 1:54 AM / IP Logged
i have tha same deck, i left that wire hangin......maybe thats why my deck is always illuminated, well whenever my car is on......
i have an old ass car and it didnt have any illumination wires......but im assuming that you just wire it up with your stock illumination wire
esmith69
Gold - Posts: 1,511
Posted: August 02, 2003 at 8:07 AM / IP Logged
Just as a general rule of thumb, If you're ever unsure about the illumination or dimmer wires you should always err on the side of caution and not connect them.  Tape each one off individually so that they do not touch a spot of bare metal  and short out something.
That wire is an illumination wire  and you would connect it to your vehicle's illumination wire, NOT its dimmer wire.  If you got a wiring harness (such as those available from Metra or Scosche) they sometimes will have the ilumination wire be solid orange and sometimes it's ORANGE / white.  In this case it's always better to just match up function to function, and disregard the coloring.
Ethan
Donate to the12volt.com
KiDFuZioN
Member - Posts: 18
Posted: August 02, 2003 at 7:05 PM / IP Logged
Thanks for the help guys.
