'91 Integra + Varad ILK to domelight
rudbwoy69camaro
Silver - Posts: 350
Posted: August 03, 2003 at 1:10 PM / IP Logged
I wanted to know if I did this right.  I connected a varad interior lighting kit to the door trigger/domelight of my '91 Integra.  When the doors are closed, it has 12V; when you open the doors it's negative.
So I had to use this:
'91 Integra + Varad ILK to domelight -- posted image.
Then I used the 12v+ output of the first relay (converting negative to positive) to give 12v+ to the remote turn on lead of the second relay:
and then pin 30 going out to the varad ILK.
My question is: Did I need to use a second relay?  Should I have just used the 12v+ output on the first relay?
Please help, Thank you in advance for your time.
rudbwoy69camaro
Silver - Posts: 350
Posted: August 05, 2003 at 8:05 PM / IP Logged
Help anybody?  Just want to know if I did it right, and if I needed to use any diodes.  Thanks !!
mobiletoys2002
Gold - Posts: 1,050
Posted: August 05, 2003 at 10:17 PM / IP Logged
all you needed was the first relay using its output for the varads. but it really dont matter the way you have it just a waste of one relay.It does the same thing both ways and i dont believe you need a diode in this aplication.
