wiring diagram needed
Left_E
Member - Posts: 13
Posted: August 13, 2003 at 3:13 PM / IP Logged
I am looking for a wirng diagram to  install a security system in a 2003 Mitsubishi Lancer..(evo rally edition)
anyine????????
I install cause i love it
cpgoose
Gold - Posts: 1,098
Posted: August 14, 2003 at 9:39 AM / IP Logged
I found this on DesignTech's website. I think you have to register with them (Free), and then you can get to it. I copied and pasted it below. Sorry for the crappy formatting, though....I think it's "Function, Wire color, and then location". Good luck.
Mitsubishi Lancer 2003
Remote Starter Wiring Colors and Notes
Start:   BLACK / YELLOW (+) Ignition switch harness
Ignition #1:   BLACK/ White (+) Ignition switch harness*
Ignition #2:   N/A Ignition switch harness
Ignition #3:   N/A Ignition switch harness
Accessory:   Blue/Black(+) Ignition switch harness
Brake Light: Green(+) Brake pedal switch
Tach Signal:   BLACK / YELLOW or BLACK/ Green (AC) Either ignition coil
Parking Lights:   GREEN/ YELLOW (L), GREEN / WHITE (R) (+) White plug at the bottom of the fuse box
Headlights:
OEM Alarm Disarm:   N/A
OEM Alarm Arm:   N/A
Diesel Glow Plug:   N/A
Clutch Bypass Wire:
Notes:
   *This vehicle may be equipped with a Transponder Type Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:   White (+) Ignition switch harness
Starter Kill:   BLACK / YELLOW (+) Ignition switch harness
Ignition +12 Volts:   BLACK/ White (+) Ignition switch harness*
Dome Lights/Superv:
OEM Horn:   RED / Black (+) Horn relay underneath the hood
Power Lock:   Purple (-) Drivers kick panel door harness
Power Unlock:   Lt.Green (-) Drivers kick panel door harness
Trunk Release:   N/A
Alarm Input Wire:
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
