Running powe wire
TheRapture
Copper - Posts: 208
Posted: July 08, 2002 at 9:05 AM / IP Logged
I need to run 2 0/1 gauge wires from my battery to the back of my hatchback to power a couple of amps...
I have a '97 Acura Integra manual....   does anyone know where I can bring these 2 thick power cables into the car from the engine compartment????????
THANKS!
trusdamanr
Copper - Posts: 116
Posted: July 08, 2002 at 12:10 PM / IP Logged
your gonna have to drill a hole in the firewall...... make sure you use a grommet  also why dont you use a distribution block     run one 0/1 wire from the battery and input it in to a distrubution block  and two outputs to the amps this way you will drill one hole instead of two.....
TheRapture
Copper - Posts: 208
Posted: July 08, 2002 at 1:00 PM / IP Logged
Actually i will be using a distrabution block... the 2 wires are one positive and one negitive to the battery instead of running the negitive to the chassis because it conducts better and is a cleaner signal. Running powe wire -- posted image.
GlassWolf
Copper - Posts: 365
Posted: July 08, 2002 at 2:57 PM / IP Logged
wrong, sir.
ground the battery as close to the battery as possible, and ground the battery to the chassis. also ground your amp as close to the amp as possible, less than 2 ft is ideal
remember cable is rated as to current carried, and distance carried. if you need 1/0 for positive, you may only meed 4ga for a short ground to be just fine.
see here:
https://www.the12volt.com/info/recwirsz.asp
If you're running 1/0 gauge, you are probably using high current amps, and thus I'd recommend you also look into a high-output alternator.
your car's alternator will have to provide the same current with it's HOT rating, as the total amplifier combined RMS power draw, plus what your car needs to run, plus at least a 10% buffer zone.
ya really need to have a good basic grasp of electricity to understand this stuff (I'm an E.E.) but trust me when I tell you a chassis ground is best. grounding amps to the battery is a very very poor idea. that will almost guarantee noise in the system, and worse yet, it actually weakens not only the power supply circuit for the response time of your amps.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
