Class D amps
troysnx
Copper - Posts: 63
Posted: August 19, 2003 at 8:20 AM / IP Logged
I've heard it's hard to hear difference in sound quality out of subwoofer amps since it's all low frequinces.  Is this true?
If so, would I be better off just buying a really cheap amp that puts out the power, or spending more and getting a class d amp with a good rep.?
R.Troy
speedwayaudio1
Silver - Posts: 879
Posted: August 19, 2003 at 9:09 AM / IP Logged
get a good class D jbl makes a good class d for under 300 bucks boss audio does aswell riot 3000D it dosn't make the full 3000w but it does slam my 8- 12's very hard.
Big Dave
wvsquirrel
Gold - Posts: 1,237
Posted: August 19, 2003 at 10:00 AM / IP Logged
When it comes to Class D amps you should look at the THD ratings (distortion). A cheaper amp will have a high THD percentage, and you run a higher risk of having more distortion in your bass. Current draw, efficiency, RMS output, and minimum impodence (ohm) stability are also other factors to look at.
The cleaner the signal that is produced, the better the SQ. The JBL BP series (BP150.1, BP300.1, BP600.1, and BP1200.1) is an excellent series. Reliable, relativly inexpensive, clean signal, good efficiency, and they are 1ohm stable. There are better amps out there, but the BP series works great if you're on a budget but still want a good quality amp.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
JamesRH
Copper - Posts: 102
Posted: August 19, 2003 at 10:06 AM / IP Logged
the JBLs are bullet proof amps for their price, Ive seen a 1200.1 run 4 12s and hit 148dB...and the subs did not get hurt either...They are clean amps
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
