Speakers are getting distortion
troysnx
Copper - Posts: 63
Posted: August 22, 2003 at 2:34 PM / IP Logged
I have a Panasonic df903u model, a pair of 6.5 type r components and a pair of kicker k525 5.25's.  The head unit pumps out about 22 watts rms to each speaker.  However, whenever I try listening to my music "loud" it begins distorting.  I'm not really listening to my music too loud, in fear of blowing my new speakers.  But I was wondering, did I wire anythign wrong?  Or is 22 watts just not enough to listen to louder music.
If an amp is the answer at hand, are JBL's good with higher frequencies, I was looking at the 80.4 (i think, well the amp put out 50x4 into 4 ohms)  I've basically been looking at sub amps so I really have no clue what amps are good for 6.5's and 5.25's.
R.Troy
DYohn
Platinum - Posts: 10,741
Posted: August 22, 2003 at 5:43 PM / IP Logged
If you are hearing distortion at volume then it's most likely the amp in the head unit clipping or just plain distorting.  I would add an external amp.  JBL makes pretty good amps (they make excellent sub amps.)  Although I am not familiar with the model you list, you probably can't go wrong with JBL.
eurotek
Copper - Posts: 58
Posted: August 23, 2003 at 7:45 PM / IP Logged
double check all your speaker connections are in phase...
also, low frequencies, even at moderate volume can cause distortion without sufficient power,,
if connections are good, you may need an amplifier, and JBL is fine
troysnx
Copper - Posts: 63
Posted: August 24, 2003 at 11:22 AM / IP Logged
Thanks for the info guys.  But I was looking at the amps and I found a good deal on the p80.4 amp I was looking at.  It says 50 watts x 4 into 4 ohms.  I have no clue how to wire into 4 ohms with door speakers.  Is there any diagrams that you guys could show me on wiring a 4 channel amp into 4 ohms?
R.Troy
bberman1
Gold - Posts: 2,314
Posted: August 24, 2003 at 12:04 PM / IP Logged
If you just wire each speaker to a its own channel +to + and - to - (you have 4 speakers and 4 channels) each channel will have a 4 ohm load and you will get 50X4.
troysnx
Copper - Posts: 63
Posted: August 24, 2003 at 12:21 PM / IP Logged
Oh I gotcha, It seemed like that was all I had to do, but since there was so little wiring I was worried I would have a very little resitence.  But apparently not.  Thanks guys!
R.Troy
bberman1
Gold - Posts: 2,314
Posted: August 24, 2003 at 2:31 PM / IP Logged
not a problem
troysnx
Copper - Posts: 63
Posted: August 24, 2003 at 2:35 PM / IP Logged
Oh one more quick question:  When wiring an amp to component speakers, do you just wiring directly to the crossovers, and keep the regular wires that run from the crossover to the driver and tweeter.  Or must you replace the wires that run from the crossover to the driver and tweeters.
R.Troy
bberman1
Gold - Posts: 2,314
Posted: August 24, 2003 at 8:45 PM / IP Logged
I’m not exactly sure I understand your question. But the amps channel hooks up to the speaker input on the X-over. then there is a connection on the X over that goes to the driver and another that will go to the tweeter they should be labeled.
troysnx
Copper - Posts: 63
Posted: August 25, 2003 at 5:09 AM / IP Logged
I'm talking about the connectiong from the xover to the driver and tweeter.  Do the outputs of the x-over need to be changed, or are the smaler wires that came with the set fine.  Can those smaller wires still handles 50watts rms?  Or do they need to be replaced?
R.Troy
