2001/2002 Chevy Trailblazer
MJwizard23
Posted: March 09, 2002 at 7:34 PM / IP Logged
Dose any body have wiring info for the new Trailblazer? 01/02 year
I hear that the doorlocks are trickey. Please Help:-)
hot_shot_guy123
Copper - Posts: 114
Posted: March 09, 2002 at 8:24 PM / IP Logged
CHEV. TRAILBLAZER 2002
WIRE COLORSLOCATION
12 VOLTS CONTANTREDIGNITION SWITCH HARNESS
IGNITION 1PNKIGNITION SWITCH HARNESS
IGNITION 2WHTIGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1ORGIGNITION SWITCH HARNESS
STARTERYELIGNITION SWITCH HARNESS
PARKING LIGHTSBRN (+)DRIVER'S KICK PANEL
DOMELIGHTGRY/BLK (+)COURTESY LIGHT
PWR DOOR LOCKSEE NOTES
PWR DOOR UNLOCKSEE NOTES
TRUNK RELEASESEE NOTES
TACH SENSORWHTIN BLUE PLUG AT ECM ON DRIVER'S SIDE OF MOTOR
BRAKEWHT (+)AT BRAKE SWITCH
HORNBLK/YEL (-)AT STEERING COLUMN
FACTORY DISARMLT.GRN (-)AT DRIVER'S DOOR MODULE IN THE DRIVER'S DOOR
FACTORY ANTI-THEFTTYPEPASSLOCK II
NOTES: Must go inside of the front Driver's door, the front Passenger door and the Rear Hatch to wire (3) separate Type C systems to the lock motors in each door. The wires are GRAY for lock and TAN for unlock. This will lock and unlock the two front doors and the rear hatch only. The middle doors, must be wired as a Type B system using the LT. BLUE for lock and the WHITE for unlock. The wires are located under the rear seat on the driver's side.
Platinum - Posts: 12,488
Posted: March 09, 2002 at 8:52 PM / IP Logged
You can go here to purchase an interface for the door lock system that will make the installation WAY easier than placing relays for the locking system:
http://www.transponderbypass.com/gmdl.asp
MJwizard23
Posted: March 11, 2002 at 9:17 AM / IP Logged
Thank you guys for the info it was very helpful.
take care
Dean
Monday, July 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
