Sensativity?
Nlzx
Member - Posts: 9
Posted: August 23, 2003 at 11:02 PM / IP Logged
I was wondering what exactly the sensativity/1w1m specs mean? Is that going to help determine how loud the woofers will be?
DYohn
Platinum - Posts: 10,741
Posted: August 24, 2003 at 8:29 AM / IP Logged
Here's the definition:
Sensitivity: A measure of the acoustic output of a loudspeaker resulting from the application of a fixed input power. Most often, sensitivity is measured in decibels at a distance of 1 meter from the source with 1 watt of input power (dB 1W/1m). It is also seen as dB at 2.83V/1m, which allows a better comparison of sensitivities regardless of load impedance. 2.83V is the amount of voltage necessary to deliver 1 watt of power into an 8-ohm load.
To answer your other question, yes, a higher sensativity rating generally means more output power (louder) for a given input.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
