tach
lenik
Posted: September 07, 2003 at 8:03 AM / IP Logged
I can't find tach wire in Ford Econoline 97. Please help!!
10nesne1
Silver - Posts: 284
Posted: September 07, 2003 at 8:58 AM / IP Logged
Here is the tach wire locations. good luck
Tach Signal:   TAN / YELLOW AT IGNITION COIL *
Notes:
   * TAN / YELLOW At Pin #5 At Ignition Control Module (ICM) Or WHITE/ PINK At Pin #3 At ICM Can Also Be Used For Tach Signal. Ignition Control Module Located On Driver Side Of Engine Compartment Behind Battery. ** See Note #211 - Ford Ignition Switch Connection Diagram.
lenik
Posted: September 07, 2003 at 9:18 AM / IP Logged
Thanks!
Where can I See Note #211 - Ford Ignition Switch Connection Diagram?
10nesne1
Silver - Posts: 284
Posted: September 07, 2003 at 9:43 AM / IP Logged
Here is Note #211 (Note #211).
Good luck
