How do I make my HU use PreAmp outs?
clake
Posted: September 07, 2003 at 8:22 PM / IP Logged
I have a Kenwood KDCX759 deck, and I'm having trouble using the RCA PreAmp Outputs for the front channel.  The deck has speaker-level outputs running from the deck to all four channels.  I just put in a new amplifier and ran RCA cables to the deck.  The problem is that the deck doesn't seem to realize that I want to use the PreAmp Outs instead of the speaker-level Outs.  Even with the new amp & speakers installed, they get no signal.  Yet the original front speakers (still in the car) work just as they did before.
So how do I set my deck to use the PreAmp Outs instead of the speaker-level Outs?
Thanks for the help!!        -Chris
auex
Platinum - Posts: 5,041
Posted: September 07, 2003 at 8:29 PM / IP Logged
A radios pre-outs should work all the time, with exception to some sub outputs. Your problem sounds like it is in your amp/wiring rather then your deck.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
aggie altima
Silver - Posts: 298
Posted: September 08, 2003 at 2:35 AM / IP Logged
I'm not sure if this is any help since you have a Kenwood, but with my Pioneer deck, I had to turn on the rear pre-outs to full range by using the menus. It has two options for the rear pre-outs, full range or subwoofer.
Did you try disconnecting the stock speakers?
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
