Wiring diagram for alarm install to 88 Toyota MR-2
Lucis0327
Posted: July 11, 2002 at 9:29 PM / IP Logged
Doing a CrimeGuard 735i install this weekend for the brother-in-law, and I'm looking for the wiring diagram information on a 1988 Toyota MR-2 Supercharged  (4AGZE engine, with A/C and manual transmission).
Platinum - Posts: 12,488
Posted: July 12, 2002 at 7:15 AM / IP Logged
Toyota
MR2
1987-1989
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ ORANGE
Ignition #2:
BLACK / YELLOW
Ignition  #3:
Accessory:
Brake  Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT IGNITER OR DIAGNOSTIC PLUG
Parking Lights:
GREEN
(+) AT FUSE BOX
Headlights:
OEM Alarm  Disarm:
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 None
Toyota
MR2
1987-1989
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE OR WHITE/ RED
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK/ ORANGE
Dome  Lights/Superv:
RED / WHITE
(-) AT DOME LIGHT
OEM Horn:
GREEN / WHITE (-)
STEERING COLUMN HARNESS
Power  Lock:
BLUE/WHITE
DRIVER'S KICK PANEL *
Power  Unlock:
BLUE/RED
Trunk  Release:
Alarm  Input Wire:
RED / WHITE
(-) AT DOME LIGHT
Notes:
* Negative Pulse Door Lock
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
