Did I screw up?
noob
Copper - Posts: 92
Posted: September 19, 2003 at 10:32 AM / IP Logged
i was laying glass in the trunk and as i was finishing up the layer i took my brush and put it in some acetone to see if it was worth saving.......after i did that i washed it off with water.......then i went to go use it later on and as i layed the resin on the mat it kinda got foamy.......i later realized that i had left some acetone in the brush............i did that last night and i checked the glass this morning and it still hadnt cured.......luckily it was only a lil spot, but is this spot gonna need something done to it.....or will it just cure in time????????
pureRF
Silver - Posts: 619
Posted: September 20, 2003 at 11:54 AM / IP Logged
I would suggest wipping most of the glass off with a rag or somthing of the sort. get as much off as u can then glass over that spot with fast curing glass.
dream it, build it, fiberglass it
rachel spencer
Posted: September 27, 2003 at 3:13 PM / IP Logged
just wash over it with a hot mix
raz
rachel spencer
Posted: September 27, 2003 at 3:22 PM / IP Logged
ps glass and water dont mix acetone is good enough on its own leave all brushes and rollers in it when you are not using them and when you get brushes and rollers out stand brushes upside down or punch holes in steel band to help drain them quicker.
raz
